I am refurbishing the brakes on my serie 1 and i see on the manual an adjustable brake master cylinder push rod on the top master cylinder for the rear brakes and a NON adjustable one for the lower one for the front brakes.
Is it correct ? i have actualy two non adjustable one ..... and my brakes are blocked after 2 or 3 foot press on the pedal and i can't adjust them !!!
thank's for the advices
brake master cylinder push rod adjustable or not ?
#1 brake master cylinder push rod adjustable or not ?
Looking for a OTS 4.2 serie 1....! and now have found a fhc xk 140
#2 Re: brake master cylinder push rod adjustable or not ?
Yes. One rod needs to be adjustable to allow for correct setting of freeplay.
#3 Re: brake master cylinder push rod adjustable or not ?
Must it be the upper one ( as i think reading the manual ) or any one ?
#4 Re: brake master cylinder push rod adjustable or not ?
Mine is the upper one.
#5 Re: brake master cylinder push rod adjustable or not ?
Thank's Andrew
#6 Re: brake master cylinder push rod adjustable or not ?
Workshop manual shows upper cylinder fitted with an adjustable fork and this feeds the rear brakes....my car is the same
