Covered headlamps - water tightness
Topic author - Posts: 1067
#1 Covered headlamps - water tightness
Hi all, my S1 got its first shower yesterday. While I am quite familiar with numerous potential water leaks into the cabin, I was surprised to see the water flowing nicely inside covered headlamps. The drainage did however work well. Certainly, I should have tested the tightness before…
Two questions:
The bonnet chrome beads do sit few mm under the headlamp chrome surround, should these be shortened to just kiss it?
Should I take some additional sealing steps or just leave as is?
Looking forward to your advice.
Two questions:
Ralph
'69 OTS + '62 OTS - Belgium
#2 Re: Covered headlamps - water tightness
They all seem to do this and although you could try sealing it with Dum-Dum or similar they still usually leak. I take the covers off and clean them on the inside which I reckon is quicker than trying to seal them.
S1 OTS OSB; S1 FHC ODB
#3 Re: Covered headlamps - water tightness
Mine leak...and a spider has now spun a web in one....can you believe it!
#4 Re: Covered headlamps - water tightness
I've tried dum dum but this only eased the leak a bit.
One point though-on my car the main point of entry is actually the seam in the wheelarch, this is where the bonnet beading sits. If you look unside the wheelarch you will see that where the seam meets the headlamp bowl panel there's a cutout to accommodate it. It's this combined with the water kicked up by the wheel the causes most of the leak. I sealed this up with dum dum putty and so far the leak has disappeared, although the current heatwave may have helped!
Alan
Alan
Alan Cochrane
#5 Re: Covered headlamps - water tightness
Thanks for the clear replies...
Is the bonnet chrome supposed to go slightly under the chrome surround or just meet it? I have tried to find close up pics without success.
Ralph
#6 Re: Covered headlamps - water tightness
Nothing on my E-Type is water tight.
Headlamps? No way.
Doors? No
Windscreen? No
Rear hatch? Nope.
Engine and radiator? No, there are constant battles with Cheney clamps, leaking radiator caps, and a suspected leaking radiator.
Not even the fuel filler cap is water tight, but once upon a time the drain hole under the flap, was. And the result? Water in the fuel tank, and about 1/2 mile later, water in the carbs.
Water leaks into the passenger cabin when it rains. I’ve no idea where it comes in, just where it ends up - on my lap and in my shoes. As most of the rubber, including around the headlamp covers, is over 50 years old, I shouldn’t complain.
Headlamps? No way.
Doors? No
Windscreen? No
Rear hatch? Nope.
#7 Re: Covered headlamps - water tightness
I would also like to know an answer to the Authors main question.
Does the bonnet chrome pipe go under the eyebrow chrome or butt up. We have been fitting the surrounds and the bead kicks them up considerably.
One solution we contemplated was filing a semi circle in the surround to accept the bead.
Many thanks
Chris
Many thanks
Chris
Chris C
1966 4.2 2+2 Gun Metal
#8 Re: Covered headlamps - water tightness
Chrome originally was bevelled so it sat on top of the surround but was not lifted up.
#9 Re: Covered headlamps - water tightness
Thanks David, by any chance would you have a picture to illustrate?
My bonnet bead chromes do sit under the glass surround and are probably preventing the compression of the rubber seal.
Ralph
#10 Re: Covered headlamps - water tightness
Suggest you contact Angus as he was pointing it out to me on his original S1 FHC. So much to see on that beautiful car I forgot to take a photo of the join.
#12 Re: Covered headlamps - water tightness
Did you slot the surrounds or cut the bead.
Looks spot on.
Chris
Looks spot on.
Chris
Chris C
#13 Re: Covered headlamps - water tightness
Angled the bead . Glad this helped
Llllllllll
#14 Re: Covered headlamps - water tightness
You can put a Mini - E- Type in one of them, under the glass. Looks funny, people love it.
Some Citroen SM folks do, the glass vitrine is huge in comparison, so you can put a Corgi or Matchbox SM in there. In the centre, near to the number plate.
With an E, I think a smaller version would work...
Carsten
Carsten
#15 Re: Covered headlamps - water tightness
Nawang61 (what's your name?)
If you can keep that fantastically good fit when you have the glass and rubber in place, you certainly deserve a medal...
Jeremy
1967 S1 4.2 FHC
1967 S1 4.2 FHC
#16 Re: Covered headlamps - water tightness
Excellent pictures thank you.
I have just attacked the first one and angled the upper bead, but for the lower bead it was easier to file the chrome surround. Huge difference now as the chrome surround sits flush all around pressing the rubber seal.
Now up to the other side, and then the water test
Ralph
#17 Re: Covered headlamps - water tightness
I know these post were long ago, but I've sealed the short section of wing joint (about 2") that extends beyond the diafragm, I think that's where most of the water gets in, I've yet to see if it leaks.
Randall Botha
'64 3.8 fhc & '51 Mk 7
#18 Re: Covered headlamps - water tightness
Using a torch in my dark garage I shone the light, under the bonnet, at the back of both the headlamps. Looking from the front I could see the light shining through at the top. Clearly this is where I’m getting dirty water in from the front wheels slinging it up whilst driving on a wet road, resulting in unsightly dirty water stains on the sugar scoops. A judicious application of silicone, until no light shines through, will hopefully cure this. They are watertight from the front even when directly hosed off while washing the car.
61 E-Type FHC Opalescent Golden Sand
16 XE R Sport 25t Polaris White - shopping trolley
