Hi, Just tidying up starter solenoid and battery cables on my 3.8. There were 2 earth wires connected to the mounting screw on the solenoid-is that where they should be?
Earth wires connection
Topic author - Posts: 244
#2 Re: Earth wires connection
Has the car been converted to negative earth? It would be useful to know this.
1964 S1 3.8 OTS
1964 S1 3.8 OTS
#3 Re: Earth wires connection
Yes Phil, it is negative earth. I think I remember changing it when I fitted an alternator!
1964 3.8 FHC
#4 Re: Earth wires connection
Okay folks, found a picture in the 3.8 Factory Fit section which shows earth wires attached to the starter solenoid mount screws. Answered my own question-relax!
1964 3.8 FHC
#5 Re: Earth wires connection
I don't understand why that would make a difference to the answer of the question asked.
'78 Land Rover Series 3 109
#6 Re: Earth wires connection
I agree that it shouldn't.Series1 Stu wrote: ↑Fri Aug 31, 2018 11:17 pmI don't understand why that would make a difference to the answer of the question asked.
There are 2 ways to wire this solenoid depending on whether you actually want it to work or not.
Sometimes people bypass it so that the only solenoid that works is the one on the starter. A simple matter of moving wires from one side of the switch to the other.
