Seeking advice re engine parts
peters3103
#1 Seeking advice re engine parts
Post by peters3103 » Fri Jul 20, 2018 3:59 am
In the near future, I plan to remove my 3.8 engine to address a lower timing chain rattle and tend to some oil leaks (rear crank seal upgrade - is this a good idea?) I’ll also replace the clutch and uni-joints and investigate the cause of a bearing?/reverse idler gear? noise when the clutch pedal is depressed.
I note SNGB have a timing chain kit available for around £90. Has anyone had any experience with the quality of these? Also any recommendations for a clutch kit?
61 FHC
99 XKR FHC
Mich7920
#2 Re: Seeking advice re engine parts
Post by Mich7920 » Fri Jul 20, 2018 12:06 pm
Hi Pete,
No problem with the timing chain from SNG.
I didn't like the new hydraulic tensiner so I made a mix between old and new.
I kept the box and only change the piston. It's working fine.
For the clutch, take the same size as your old of course and ask a trade mark item
Ask them to sale you the best quality they have and not repro when it's possible.
Mich
Michel
1965 E Type FHC - On the road - 1963 E Type OTS - Angus Restoration
Gran Torino Sport 1975 - Renault 4cv 1956 - CItroen 15/6 1951 - CItroen Traction 1945
Citroen Coupé docteur 5Hp 1924 - Citroen B12 1926 - Torpedo Sygma 1913
Harley D. 1915 sidecar
#3 Re: Seeking advice re engine parts
Post by malcolm » Sun Jul 22, 2018 8:35 am
Although mine is a series 2, I got a new 3 piece clutch set from SNG and it is fine.
peters3103
#4 Re: Seeking advice re engine parts
Post by peters3103 » Tue Jul 24, 2018 11:43 pm
Thanks for this info, much appreciated
61 FHC
99 XKR FHC
rfs1957
#5 Re: Seeking advice re engine parts
Post by rfs1957 » Mon Oct 01, 2018 3:54 pm
I'm aware that there are lots of noises both in the trade and on forums about the quality and longevity of the timing-chain and tensioner assembly parts being sold at the moment.
Some horror stories about very short life-span etc
I even considered re-fitting my old parts as they look fine and have been in there nearly 30 years.
The timing-chain "set" from SNGB is indeed very cheap, £82 in fact.
However, "original quality" it is most definitely not, and if you ask SNGB for the best stuff they've got, the tensioner at least is genuine Jaguar (does that mean anything ?), the chains look very Chermann, and the cost of the same "set" comes to £198.
I'll happily spend the £116 difference if I can be sure that I'm not going to see the pads de-bonding after 3.000 miles.
But if the £82 set de-bonds after 3.000 miles, why would anyone sell them anyway ?
And if they don't de-bond why am I spending the extra £116 ?
Au secours.
1978 Mini Van
Mich7920
#6 Re: Seeking advice re engine parts
Post by Mich7920 » Mon Oct 01, 2018 5:43 pm
Hi Rory,
It's like the hotel. If you take a room in 4 stars you have all the chance to receive smiles and good service. If you take it in a 2 stars you receive ... a key!
But of course, and in all case, you could find an exception.
for all the time I spend on my E I prefer the higher quality parts even if it's more expensive.
Mich
Michel
Jeremy
#7 Re: Seeking advice re engine parts
Post by Jeremy » Mon Oct 01, 2018 6:44 pm
I would recommend contacting Rob Beere and see what he offers. Only today he was telling me about these very problems with inconsistent aftermarket tensioners - they had to rebuild an engine after one of these came apart and wrought havoc.
Jeremy
1967 S1 4.2 FHC
#8 Re: Seeking advice re engine parts
Post by abowie » Mon Oct 01, 2018 11:08 pm
Use the Landrover tensioner. Don't use chains with joining links.
AP branded clutches are available from the usuals and this is what we use.
Rear oil seal "upgrades" are a lottery; some people are very happy with them, others not so. I have had good success with the standard rope seals on my cars.
If you have a Moss box noisy operation is normal. While bearings, seals and shafts are available new, none of the other components are so you are pretty much stuck with what you have. Having said that, if you plan to remove the engine, rebuilding the gearbox is always a good idea; about $1k in parts and $800 in labour.
