3.8 Indicator white plastic cancelling ring
George4422
#1 3.8 Indicator white plastic cancelling ring
Post by George4422 » Mon Nov 05, 2018 5:33 pm
Hi everyone,
I realise that this subject has been discussed before, but I am wondering if there is now a supplier of these elusive items?!!
Any help would be very much appreciated.
George Webster
lopena
#2 Re: 3.8 Indicator white plastic cancelling ring
Post by lopena » Mon Nov 05, 2018 6:06 pm
George:
If you’re talking about the white plastic canceling ring that resides inside the turn signal switch, there’s good news: XK’S Unlimited in the U.S. sells these items for U.S. $19.
Alan
New Jersey
George4422
#3 Re: 3.8 Indicator white plastic cancelling ring
Post by George4422 » Mon Nov 05, 2018 6:12 pm
Hi Alan,
Many thanks for the reply, but it's the castellated ring (usually white plastic) that the two 'fingers' from the switch itself engage with to cancel the indicators that I'm seeking.
George
lopena
#4 Re: 3.8 Indicator white plastic cancelling ring
Post by lopena » Mon Nov 05, 2018 7:07 pm
George:
Understood.
No...I’ve never seen those for sale from the usual vendors here in the States.
Maybe you can find someone with a 3-D printer to make a small batch?
Good luck,
Alan
#5 Re: 3.8 Indicator white plastic cancelling ring
Post by Heuer » Mon Nov 05, 2018 7:41 pm
Someone on J-L made one on a 3D printer. Worth checking over there and see if he can make more or offer the data.
S1 OTS OSB; S1 FHC ODB
George4422
#6 Re: 3.8 Indicator white plastic cancelling ring
Post by George4422 » Tue Nov 06, 2018 10:39 am
Hi David,
Thanks for the reply and all I have seemed to turn up on the JL site is the smaller white 'spring-like' part that is integral to the switch and not the castellated cancelling ring...
If anyone has a scan of this I'd welcome a copy of the data.
Thanks,
George
#7 Re: 3.8 Indicator white plastic cancelling ring
Post by Heuer » Tue Nov 06, 2018 10:52 am
Just been told that Marek makes the cancelling ring. Suggest you PM him.
ysmalkie
Poland
#8 Re: 3.8 Indicator white plastic cancelling ring
Post by ysmalkie » Thu Nov 08, 2018 9:44 pm
Marek, can you share a photo of the cancelling ring?
Also, I was looking for someone that remakes the plastic end of the indicator stalk - anyone out there does it?..
Tadek
Tadek
Jaguar XK120 OTS
Austin-Healey 100 BN2
#9 Re: 3.8 Indicator white plastic cancelling ring
Post by MarekH » Thu Nov 08, 2018 9:58 pm
You'll have to send me your email address - I don't have a copy of it to hand any more. Alternatively, there ought to be some pictures on J-L if you search there.
ysmalkie
Poland
#10 Re: 3.8 Indicator white plastic cancelling ring
Post by ysmalkie » Fri Nov 09, 2018 8:54 am
I have one more question on the cancelling ring issue. It seems my striker has the 'tongue ' broken.
It's probably part no c16451.
This is how it looks like:
Anyone has a ring like mine and could possibly measure the total length of this tongue?
I would be most grateful...
Tadek
Tadek
Jaguar XK120 OTS
Simonpfhc
#11 Re: 3.8 Indicator white plastic cancelling ring
Post by Simonpfhc » Fri Nov 09, 2018 10:56 am
Hi Tadek,
Don’t have it to hand so can’t measure it for you, but here is a decent picture to give you an idea:
Cheers.
62 3.8 FHC
91 Porsche 928GT
ysmalkie
Poland
#12 Re: 3.8 Indicator white plastic cancelling ring
Post by ysmalkie » Fri Nov 09, 2018 11:19 am
Thanks!
Seems like 26.6-27mm to me.
Cheers, Tadek
Tadek
Jaguar XK120 OTS
#13 Re: 3.8 Indicator white plastic cancelling ring
Post by Heuer » Fri Nov 09, 2018 11:21 am
Jaguar would have used imperial measures so it will be in inches and/or fractions of inches. Never try measuring anything on an E-Type in metric! That is probably why many reproduction parts don't fit. :idea:
ysmalkie
Poland
#14 Re: 3.8 Indicator white plastic cancelling ring
Post by ysmalkie » Fri Nov 09, 2018 6:42 pm
How does 1 1/16" sound? :geek:
Tadek
Tadek
Jaguar XK120 OTS
#15 Re: 3.8 Indicator white plastic cancelling ring
Post by Heuer » Fri Nov 09, 2018 8:11 pm
1" sounds more correct for a non critical part.
ysmalkie
Poland
#16 Re: 3.8 Indicator white plastic cancelling ring
Post by ysmalkie » Mon Nov 12, 2018 2:12 am
Simon,
Does this setup require the plastic ring?? I can't see it in the part's manual..
I have a '63 3.8 and am wondering if I need the plastic cancelling ring - it was not there when I bought te car, but then the steering column was in a mess..
Tadek
Tadek
Jaguar XK120 OTS
