The hinges for the fold down boot board as listed on SNGB as BD24400.
Were there different hinges used early on? I cant find any holes or indication of hinges that would work in the way the above hinge does.
But there does appear to be holes that would allow for a simple flat piano hinge.
Boot Board Hinges
#1 Boot Board Hinges
#2 Re: Boot Board Hinges
Hi Steve,
I think earlier cars had door like hinges; I assume the 3.8's, but I don't know until when.
You dont say what year your car is.
#4 Re: Boot Board Hinges
your three hinges should be BD20131
Fitted from Chassis No.
860581 to 861098. 886093 to 888301.
The later hinge is BD24400
Fitted to Chassis No.
861099 and subs. 888302 and subs.
BTW BD23142 is for the hinged panel striker and not a hinge.
Hope this helps,
Klaus
Hope this helps,
Klaus
Klaus
1963 E-Type FHC 889633, 1979 Porsche 928, 1991 Mazda MX-5
#5 Re: Boot Board Hinges
Thank you Klaus. Correct my mistake. Read the wrong line. :-)
