locking door failure....
Polse7317
#1 locking door failure....
Post by Polse7317 » Mon Nov 26, 2018 3:11 pm
I have a problem with the new key / lock parts on each door. I can't close the door : when i turn to close with the key it operate the lever with its spring down as it does... but when i take off the key from the door, the door is no more closed because it makes the spring lever up and disclose the lock ...
Am i missing some part of the lock ?
1 : key
2 casing for the lock + new lock
3 washer with two internal tabs
4"piston" wich must turn on itself in some location when i turn the key
5 spring
6 case holding the operating lever
7 operating lever
8 adjustable screw with its bolt
I think i must have a problem with the part 4 which seeems to be disconnected sometimes when i turn the key .
May be this part is worned at its end.
PS: What is the use of the little round hole in the part 7 ( location of a kind of pin ?)
Any advice is welcome :seeingstars:
#2 Re: locking door failure....
Post by politeperson » Mon Nov 26, 2018 8:20 pm
In my experience of these locks the problem is usually with the adjustable linkage. It is the next step in the chain and has three possible adjustment points.
http://forum.etypeuk.com/viewtopic.php? ... hilit=lock
James
James
L.J.K. Setright was right.
Polse7317
#3 Re: locking door failure....
Post by Polse7317 » Mon Nov 26, 2018 9:59 pm
Thank's James, i'll have a look on that part ASAP ...... :idea:
