Cylinder Head Numbers
garcormack
#1 Cylinder Head Numbers
Post by garcormack » Sat Feb 16, 2019 8:49 pm
Dear All
I don't believe my cylinder head is original to the car (1963 series 1 3.8 fhc) and guess that the numbers/letters on the head could help identify its origins.
The numbers/letters are
ZB-3445-8 at valley front
A in valley middle
AA476 at valley rear.
Could anyone help or point me in the right direction?
Many thanks
Gary
cactusman
#2 Re: Cylinder Head Numbers
Post by cactusman » Sat Feb 16, 2019 9:45 pm
Pretty sure original heads are four digit numbers prefixed by R or RA. My 62 car is R5xxx....others will know for sure though. Pretty certain there are engine number lists in the knowledge base but can't seem to find them for the moment......David...help :bigrin:
#3 Re: Cylinder Head Numbers
Post by rswaffie » Sat Feb 16, 2019 10:19 pm
I think that head may be from a MK10.
S1 3.8 FHC Opalescent Golden Sand 889504
Undergoing a comprehensive restoration in my small, but utilitarian garage :wrench: :hammer: :fingerscrossed:
Geoff Green
#4 Re: Cylinder Head Numbers
Post by Geoff Green » Sat Feb 16, 2019 10:44 pm
garcormack
#5 Re: Cylinder Head Numbers
Post by garcormack » Sat Feb 16, 2019 11:09 pm
Thank you all
The ZB prefix implies a Mk 10 although the A designation doesn't support this. The 8 at the end does suggest an 8:1 compression ratio.
Gary
#6 Re: Cylinder Head Numbers
Post by christopher storey » Sun Feb 17, 2019 9:24 am
The A and the AA number will merely be a foundry batch identification , and has no significance at all. Definitely a 3.8 mark X head . Note that the -8 may not be applicable any more ; the CR is determined not by the head, but by the pistons i.e. the heads are identical irrespective of the CR of the engine, the small domed pistons being 8:1 and the large domed pistons 9:1
Last edited by christopher storey on Sun Feb 17, 2019 9:27 am, edited 1 time in total.
garcormack
#7 Re: Cylinder Head Numbers
Post by garcormack » Sun Feb 17, 2019 9:26 am
Thank you Christopher
Much appreciated
Gary
#8 Re: Cylinder Head Numbers
Post by christopher storey » Sun Feb 17, 2019 9:28 am
Gary : note that I have added info about the CR, which may or may not help you !!
