A post trimming
paulsco
#1 A post trimming
Post by paulsco » Mon Mar 11, 2019 1:13 pm
When looking at the A post through the windscreen at the front, there is a U channel in the A post from top to bottom.
The windscreen rubber mounts on the outside one and the front part of the cant rail curves around the inner one.
On my FHC, you can see the bottom of this U section between the rubber and the cant rail.
My question is: is this normal; is this U channel covered in vinyl, or should the padding on the cant rail trim be thicker to fill this gap?
Thanks,
