I don't think there is a welded seam, just the line between two halves of the mould. I am guessing but I think they are blow moulded.
To be fair to SNGB they have no control over how these are fitted. If the pipe is too long it will stress the spigot when the bottle is clamped in place. Ideally the hose would be cut to a length that prevents any excess being taken up by bending of the spigot.
My process now is:
1. With a dab of red rubber grease push the hose onto the spigot
2. Attach the bottle to the bracket and loosely tighten
3. Put two clamps on the hose and secure the top one
4. With red rubber grease on the copper pipe slide the hose on and dress so there is minimal stress on the bottle. The grease makes this easy.
5. Tighten lower clip, tighten upper clip, tighten bottle bracket
6. Ensure the clips are the correct size for the hose. If in doubt check tightness with a spare piece of hose and pipe
7. Check the supplied hose is of the correct type. This subject is fully detailed elsewhere on the Forum. Using the incorrect hose may lead to it 'sweating' brake fluid onto the frame.
http://forum.etypeuk.com/viewtopic.php?p=15015#p15015
This build sequence seems counter intuitive as it would seem easier to put the bottle on the hose last.
