Fixing the Y trim piece on centre console
paulsco
#1 Fixing the Y trim piece on centre console
Post by paulsco » Sat Jun 15, 2019 4:49 pm
Does anybody have a picture of the underside of the Y shaped trim piece on the centre console?
It would appear that mine has been modified (shortened) by the PO and it is unclear what is original and what is not.
I am trying to establish how it is fixed on to the console.
Also is the gauntlet panel where the gear leaver passes through screwed to the bottom; screws upwards, or the top; screws downwards of the centre console.
Oh and can I ask for the mesurement on the console from the remost bend to the end of the console; I think this too has been cut off short.
Thanks,
#2 Re: Fixing the Y trim piece on centre console
Post by christopher storey » Sat Jun 15, 2019 5:31 pm
Paul : I think it would be helpful if you could post a picture of what you have, as the pieces are difficult to recognise from your description. This particularly applies to the "Y shaped piece"
#3 Re: Fixing the Y trim piece on centre console
Post by abowie » Sat Jun 15, 2019 8:43 pm
Mine's at the trimmer but I can tell you that it is held to the rest of the console by metal tabs on it that fold around the console.
rfs1957
#4 Re: Fixing the Y trim piece on centre console
Post by rfs1957 » Sun Jun 16, 2019 6:35 am
If 1962 with the pimpled alloy upper is any good to you, my centre section is complete and trimmed but off the car and I can photograph and measure the item. The Y piece you refer to has to be the top surface that is forked to straddle the gearchange orifice, right ?
#5 Re: Fixing the Y trim piece on centre console
Post by PeterCrespin » Sun Jun 16, 2019 9:31 am
The lever surround fits from under and screws face up. Combined pieced held by tabs but lengths vary according to cubby type (none/long/short 2+2).
paulsco
#6 Re: Fixing the Y trim piece on centre console
Post by paulsco » Sun Jun 16, 2019 9:55 am
Hi Guys,
Thanks for your responses.
Here are some ugly pictures of what I have:
So the Y piece is held on with the tabs; thank you Andrew.
My Y piece, the brown crushed velvet in the picture, from what I have discovered so far, does not have the tabs at the front, so this needs to be addressed, but at the back, I can see that two tabs could hold it on in the hand brake hole, but I can't see what would hold it on on the right hand side.
Rory; I am not sure if the early 3.8 one would be the same length as the 4.2, but would be grateful for the measurement if it is not too difficult for you. I can work out the length of the Y piece from the cubby box position, but the main body is not so obvious.
Pete; thanks for the information on the fitting of the gauntlet panel and the 2+2 differences.
rfs1957
#7 Re: Fixing the Y trim piece on centre console
Post by rfs1957 » Sun Jun 23, 2019 8:20 pm
Paul, see the PM I sent you a couple of days ago.
R
paulsco
#8 Re: Fixing the Y trim piece on centre console
Post by paulsco » Mon Jun 24, 2019 2:15 pm
Hi Rory,
I have responded to your PM.
Thank you for your help.
