What size are the 'swivel' bolts for the balance link (not the special shouldered ones)? Mine are 1/4" UNF but there appears to be lots of 'slop'. Sizes are not specified in parts book.
Bonnet balance link assy. bolts
Topic author - Posts: 202
#2 Re: Bonnet balance link assy. bolts
If you mean the bolts that fix the links to the bonnet then mine are 1/4 unf with special oversized washers
#3 Re: Bonnet balance link assy. bolts
no, I mean the bolts on which the spring assy 'pivots' i.e. as the bonnet opens the mechanism opens pivotting round these bolts.
1964 3.8 FHC
#4 Re: Bonnet balance link assy. bolts
Originally these were held together with rivets and special brass washers.
Not uncommonly the rivets failed or someone pulled them apart to restore them, and were replaced with bolts.
881824, 1E21538. 889457..oops
#5 Re: Bonnet balance link assy. bolts
Andrew,
Yes, on my 63 FHC I had one side with the rivet and the other with a machine screw/nut/washer.
Now running-in my diy nut ‘n’ bolt restoration.
#6 Re: Bonnet balance link assy. bolts
1/4" UNF bolts removed. Holes are 5/16". 'Special' shouldered bolt and brass washers fitted to picture frame swivel and 5/16" bolts and brass washers fitted to other two,originally rivetted ,holes. No slop now!
1964 3.8 FHC
