- Administrator
Post
by Heuer » Sun Jun 07, 2020 1:02 pm
sheryllee wrote: ↑Thu May 07, 2020 12:15 pm
Hydraulic clutches are generally not adjustable in the same way that a cable clutch is. The only adjustment is in the height and free play of the pedal itself. This can be adjusted typically using a nut at the top of the clutch pedal lever. ... Hydraulic clutches are mostly not adjustable, because they are self adjusting.
Thanks for your contribution however can you please add your name and model of car to your signature as it will help other members to assist.
