flasher unit
valerea
#1 flasher unit
Post by valerea » Tue Aug 18, 2020 10:08 am
hi
I am converting my S1 from LHD to RHD and currently rewiring.(finding it a bit of a pain as the car seems an amalgam of 1 and 2 series!) I would appreciate any photos showing the cockpit wiring loom layout. My autosparks loom seems to have the flasher canister on the RHS...is this correct? For the LHD it was on the LHS. I would also appreciate any advice on ensuring the indicator stalk is on the correct side.
the car is Dec66 roadster
many thanks
#2 Re: flasher unit
Post by rswaffie » Tue Aug 18, 2020 10:13 am
I converted my 63 from left to right hand drive, using complete loom set. The flasher unit moves from left side to right side.
#3 Re: flasher unit
Post by Heuer » Tue Aug 18, 2020 10:22 am
If you go to our Knowledge Base you will find links to a set of guides by Mike Cassidy detailing LHD/RHD conversion: viewtopic.php?f=16&t=700
S1 OTS OSB; S1 FHC ODB
