I have a series 1 2+2 which is nearing completion of a four year restoration.
The trimmer has concerns about the bulk of the loom in the passenger footwell. He is suggesting it’s way too bulky. I managed to get the original steel panel which holds this bulk of cables in the FHC but the 2+2 appears to be different and there is of course an shelf to go in as well.
Could anybody help with how this was trimmed together with how the shelf fitted with the cable bundle. I would be grateful for any pics as I am sure others doing a 2+2 would. I am wondering if the builder who is different from the trimmer has put the cables in and out of the wrong holes creating this bulk which is now difficult to neatly trim. I am wondering if we need to make a larger metal conduit.
Many thanks for any help.
Chris
S1 2+2 wiring loom and footwell
#1 S1 2+2 wiring loom and footwell
Chris C
1966 4.2 2+2 Gun Metal
#2 Re: S1 2+2 wiring loom and footwell
Hi I ahave just completed my 2+2 and retrimmed the origional cover which went along the top above the shelf I have attached some pictures taken when stripping the car as I cant find one when putting it back in but can take some photos when back home tomorrow if you want
Trevor
Trevor
Trevor Hanna
1967 Series 1 2+2 Carmen Red
#3 Re: S1 2+2 wiring loom and footwell
Recently finished mine with no problems in this area. I used a piece of metal conduit underneath the card cover shown in Trevors picture. Make sure the large P clip is in place in the footwell where the loom passes through into the engine bay. Its a bit of a bugger to fit. Has the installer correctly positioned the loom with all the branches that run off to the heater, voltage regulator and heater all inside the engine bay?
Richard Marsh
1967 Series 1 UK RHD 2+2
#4 Re: S1 2+2 wiring loom and footwell
Sorry for not coming back earlier did not seem to get a notification of your kind posts.
Is it possible to get a picture of your cable entry points. Just to make sure mine is correct. Trimmer seems to think there is too much bulk compared to FHC.
Would you have had as much cable as before you trimmed as you see in my pic;
Many thanks
Chris
Many thanks
Chris
Chris C
#5 Re: S1 2+2 wiring loom and footwell
#6 Re: S1 2+2 wiring loom and footwell
Thanks for that. Yes looks like a similar amount of spaghetti.
Chris
Chris
Chris C
#7 Re: S1 2+2 wiring loom and footwell
#8 Re: S1 2+2 wiring loom and footwell
Thanks again
Chris
Chris
Chris C
