Chassis plate fixing area S1
Topic author - Posts: 4
#1 Chassis plate fixing area S1
Can anybody please tell me whether the chassis area fixing location of a S1 3.8 is absolutely flat or curved, or can either end finish be found on standard vehicles?
#2 Re: Chassis plate fixing area S1
I think it's probably supposed to be flat but often it has a slightly convex curve to it, as you're alluding to.
I've always assumed that this was a function of getting that corner box section to come together properly.
#3 Re: Chassis plate fixing area S1
My early 4.2 (with several 3.8 features) has a definite slight arch to the chassis plate fixing area. Car has all original panels with no repair work, btw.
'65 S1 4.2 FHC
'65 S1 4.2 FHC
#4 Re: Chassis plate fixing area S1
Excellent thank you. That's put my mind at rest. Both sides are definitely concave. The old girl is as straight as an original E Type could be after 56 years. The paint and panel sealer is not lifted and there's not evidence of anything thereabouts being lumped but it was a concern because I'd not noticed it before I removed the chassis plate.
Steven
Steven
#5 Re: Chassis plate fixing area S1
Hi Steven,
This area is part of the inner sill, so has the same contours.
I would say slightly convex towards the inside, but otherwise flat.
