Refubrishing series I seats
Desmo
#1 Refubrishing series I seats
Post by Desmo » Mon Jan 04, 2021 3:35 pm
Hello,
Can the original leather covers of the early series I seats be removed from the seat frames and seat cushions without damaging and after the upholstery refurbishing then attached again? Does anyone have experience with this and and what should I pay attention to? Are there any instructions on the internet? Thank you for your help.
#2 Re: Refubrishing series I seats
Post by Heuer » Mon Jan 04, 2021 5:29 pm
Very difficult to do as the Vaumol leather hardens over time and will crack when you try to stretch it. Also the leather was trimmed after being attached to the frame so you have next to no way of holding/stretching it into place. Connolly have started producing Vaumol again so that is your best path. Expensive but worth doing if you want to get the original texture. More info here: http://forum.etypeuk.com/viewtopic.php?f=16&t=1384
S1 OTS OSB; S1 FHC ODB
Javelin
#3 Re: Refubrishing series I seats
Post by Javelin » Wed Jan 06, 2021 4:50 pm
We are just in the process of doing just this, and so far no problems. When I get a chance, I will put a photo or two up but as lockdown is back, I'll not be seeing the seats for a while.
Technical Adviser to a :bigrin:
S1 2+2 4.2
1966
Desmo
#4 Re: Refubrishing series I seats
Post by Desmo » Thu Jan 07, 2021 11:00 am
Hello Steve,
This would be lovely. I am very interested to see how the material and also the moquette material is fixed on the frames and what is best method to remove the moquette material without damaging it. Overall, the seat covers are very well preserved and still relatively flexible.
Best regards
#5 Re: Refubrishing series I seats
Post by mgcjag » Thu Jan 07, 2021 11:19 am
Are you guys talking about the same type of seat....John..im assumeing yours are the bucket type...where as i think Steve is refering to the late seat with a base and seperate backreast.....please comfirm what you have....Steve
max-it-out
#6 Re: Refubrishing series I seats
Post by max-it-out » Thu Jan 07, 2021 11:43 am
The leather on my seats , and particularly the gear lever bit ,had gone hard . I tried the cheap baby oil from the supermarket . Repeated applications over a couple of months have transformed the condition - it`s now super soft and pliable - amazing and cost next to nothing . :salute:
1968 series 1.5 roadster
#7 Re: Refubrishing series I seats
Post by Heuer » Thu Jan 07, 2021 12:36 pm
The gear lever gaiter on the later 4.2 cars was made of synthetic Ambla. Jaguar used Connolly Vaumol leather for the seats on all E-Type's.
- Vaumol was patented by Connolly in 1939
- The base colour and clear top coat were cellulose and sprayed on - it is not through dyed
- By the mid 1980's the process was changed to use part cellulose and part water based paints
- By the early '90's the paints were all water based
- Vaumol has not been produced since 1998, 'real' Vaumol not since 1986
- If you find any new old stock it is likely to be useless as the paint will crack on stretching as it does not store well
- Nothing can reproduce the smell, finish or feel of Vaumol leather
- Connolly restarted Vaumol production in 2017
If you are thinking of renovating a Connolly leather interior, or any leather interior in fact, start by ensuring the interior is thoroughly cleaned with glycerine soap (or use mild toilet soap, not caustic nor detergent soaps for routine wiping over). Use a small nail-brush to remove ingrained dirt. Avoid flooding and wipe off the residue. Whilst still damp, apply a coat of CeeBee hide food, which will restore the original suppleness and nourish the fibres. Allow this to be absorbed for 24 hours, after which any surplus should be wiped off and the result should be a nicely-polished surface. If the original colouring has worn away, new lacquer can be applied. This should be swabbed on evenly and sparingly using one or two coats. Unfortunately cracked or torn leather, caused by the cracking of the foam-rubber base, will have to be replaced. This can be avoided if you cover the foam with linen before stitching on the leather upholstery.
As modern leathers use a completely different finishing system consequently they do not need to be treated with aftercare products containing oils. The majority of renovation creams marketed today will remain on the leather surface, and simply attract dirt and dust. Recommended treatment for modern leather appears to be Dr Leather wipes.
Desmo
#8 Re: Refubrishing series I seats
Post by Desmo » Thu Jan 07, 2021 1:59 pm
Hello,
Yes the early bucket seats.
#9 Re: Refubrishing series I seats
Post by mgcjag » Thu Jan 07, 2021 2:33 pm
Hi John....there are videos on youtube..just google e type bucket seat refurb or re cover....Steve
Javelin
#10 Re: Refubrishing series I seats
Post by Javelin » Thu Jan 07, 2021 9:29 pm
Ooops .. Yes, the later base and backrest.
S1 2+2 4.2
1966
Joes66
#11 Re: Refubrishing series I seats
Post by Joes66 » Sun Jan 10, 2021 5:24 pm
Try furniture clinic
They have detailed tutorials on leather seat refurbishment
They are on u tube
Their products are also excellent
I recently did all my seats in my series 2 using their stuff and it all came out very nicely
Well worth watching the tutorials
Joe
1969 series 2 2+2
Desmo
#12 Re: Refubrishing series I seats
Post by Desmo » Sun Jan 10, 2021 10:35 pm
Hello,
many thanks. Unfortunately, I cannot find any information on how to remove the seat covers from the early bucket seats or what to look out for by dismantling the units. This would be very helpful to get an idea of what the internal structure of the seat cushion and backrest look like. We will see.
Best regards
#13 Re: Refubrishing series I seats
Post by mgcjag » Mon Jan 11, 2021 8:53 am
Hi John...as i mentioned befor but have a look here
Desmo
#14 Re: Refubrishing series I seats
Post by Desmo » Mon Jan 11, 2021 10:21 am
Hello,
Yes I have seen this video. However, BAS only shows as many details as necessary, which is understandable. I would like to see how the interior of an original seat cushion and backrest are constructed. I think that I will find a solution. Thank you.
Kind regards
#15 Re: Refubrishing series I seats
Post by mgcjag » Mon Jan 11, 2021 10:49 am
Hi John....I assumed your seats are original.......so by dismantling them you will know exactly how they are constructed......it shouldnt be very difficult to then reassemble especially as your leather is already moulded into shape......Steve
