Headlight bulbs
phoenix
#1 Headlight bulbs
Post by phoenix » Fri Jan 22, 2021 11:07 pm
Hi all what in your opinion are the best bulbs to use for the covered headlights . Including HID etc .
S1 4.2 RHD Bryan
#2 Re: Headlight bulbs
Post by Heuer » Sat Jan 23, 2021 11:52 am
Relay conversion along with the latest generation super-bright halogen bulbs from Phillips or Ring. http://forum.etypeuk.com/viewtopic.php?f=9&t=4919
HID will not fit and would not be legal as they require headlamp washers and self levelling suspension. LED's are a similar legal minefield and there is talk of strengthening the existing legislation to outlaw retro fittment completely due to dazzling oncoming drivers. Also the S1 sloped headlamp buckets make fitting of 'upgraded' refelctors and electronic bulbs difficult.
S1 OTS OSB; S1 FHC ODB
#3 Re: Headlight bulbs
Post by rswaffie » Sat Jan 23, 2021 12:32 pm
:yeahthat:
I use H4’s with the relay upgrade and they are on a par with my 2005 Audi. Even the mot tester commented on the performance when they did the calibration for me.
cactusman
#4 Re: Headlight bulbs
Post by cactusman » Sat Jan 23, 2021 1:44 pm
I second Richard. Use good quality branded H4 60/55 watt filament bulbs from E.g Bosch or Philips. Don't buy cheap unbranded rubbish from a well known auction site. Don't be tempted to get higher wattage ones unless you have the relay conversion....and even if you do it is not really necessary.
LED bulbs are available but the vast majority either won't fit or will not dip correctly due to incompatibility between the reflector that is designed for a filament H4 and the LED source. And yes, at least one supplier is now selling an LED conversion that will fit but I'd still be dubious about its dazzle when dipped. As David says HID are definitely illegal as the lights don't self level.
#5 Re: Headlight bulbs
Post by mgcjag » Sat Jan 23, 2021 7:52 pm
Osram H4 nightbreaker......very good
cactusman
#6 Re: Headlight bulbs
Post by cactusman » Sat Jan 23, 2021 8:42 pm
:yeahthat:
johnetype
#7 Re: Headlight bulbs
Post by johnetype » Sat Jan 23, 2021 9:28 pm
:yeahthat: but actually Osram H4 Nightbreaker Laser which give +150%.
1969 Series 2 FHC
Polse7317
#8 Re: Headlight bulbs
Post by Polse7317 » Wed Jan 27, 2021 8:16 am
I have just "moted" my Serie 1 with LED from "bettercarlighting " and it was good but you have to adjust the bulb rotation with the light triangle on the right side (FRANCE) to avoid dazzling
