Master Brake/ Clutch Cylinder Aluminium Tags
caveman
#41 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Post by caveman » Sun Aug 27, 2023 2:10 pm
jaspercat10 wrote:
Fri Aug 11, 2023 4:54 pm
Been trying to get a response from him on this? Is anyone else receiving anything ?
Nothing :shrug:
1965 S1 4.2 FHC (early)
caveman
#42 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Post by caveman » Sun Aug 27, 2023 2:17 pm
Allrand
#43 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Post by Allrand » Mon Aug 28, 2023 6:26 am
Maikel wrote:
Mon Oct 17, 2022 5:46 am
Good day,
If nobody has an earlier date, we could as per today agree that the aluminum tags were used until 11/62.
Hi Maikel, what other numbers are on the plastic tags?
Randall Botha
'64 3.8 fhc & '51 Mk 7
Maikel
#44 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Post by Maikel » Tue Aug 29, 2023 2:55 pm
Happy to share,
I am posting some pics I have taken, as you can see, one is clutch the other is brake.
Hope you can assume what is what.
clutch dated 12 62
VBM 4705 assuming
C. 19967
lower brake master dated 12 62
VBM 4706
C. 19968
assuming upper brake master dated 12 62
VBM 4707
C.19969
Maybe someone can confirm. It seems the plastic tags did have a consecutive number where then the date of inspection had been squeezed in.
Allrand
#45 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Post by Allrand » Wed Aug 30, 2023 9:31 am
Thank you Maikel, that's very useful info.
Randall Botha
Dave K
#46 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Post by Dave K » Fri Sep 08, 2023 8:07 pm
I still have the original ones fitted to my brake master cylinders. The clutch one disappeared at some point and wasn't on the car when I got it.
Philk
#47 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Post by Philk » Sat Sep 09, 2023 7:34 am
Would be great if someone could produce a set of the plastic ones with the correct part nos. stamped into them.
1964 S1 3.8 OTS
skippy
#48 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Post by skippy » Fri Jan 19, 2024 6:08 am
There is a very nice bloke on ebay that is selling the stamped aluminium tags - 1961 to early '62. He has maybe 20 sets left.
He cut these over 5 years ago and only had questions for the drawing. Please don't contact him for a drawing.
Hope I'm not breaking a forum rule David.
Keith
