Hi, I am wondering if I am missing a Horn Push Spring here.
Or, do the very early 1961 series 1 horn push just rely on the Spring (16880) as item 14 in the parts manual to hold the horn push off of activating?
1961 Original Horn Push question
#1 1961 Original Horn Push question
Clive
August 1961 Flat floor ots
#2 Re: 1961 Original Horn Push question
Hi Clive,
I'm pretty sure all S1 cars are the same with a spring in place at top. See link here for a clear picture:
viewtopic.php?f=4&t=19362&p=157395&hilit=Horn#p157395
1965 S1 4.2 FHC (early)
#3 Re: 1961 Original Horn Push question
Yes, you most definitely need a spring and sometimes to ensure the horn push is correctly pushed back into the housing to provide movement forward on depressing the horn push, a supplementary spacer - such as a small nut is used on top of the contact pin assembly.
Dave Rose
1967 Series 1 4.2 FHC
#4 Re: 1961 Original Horn Push question
Okay, thank's guys. So its a spring on the long rod - and no spring in between the horn push button and its housing.
Clive
#5 Re: 1961 Original Horn Push question
and exactly as the diagrams above.
