No affiliation, but for those interested, the copy of the original Top Radiator Hose with Stocking Finish is available from old Bill Tracy stocks here:
https://www.memotronics.com/top-radiato ... uar-xk150/
David Jones mentioned it here:
viewtopic.php?f=4&t=2006&p=100267&hilit ... 50#p100267
The fellow who bought Bill Tracy stock contacted me by coincidence, I was not aware that his stuff is still out there.
Tadek
early S1 top Radiator hose availability
#1 early S1 top Radiator hose availability
Tadek
Jaguar XK120 OTS
Austin-Healey 100 BN2
Jaguar XK120 OTS
#2 Re: early S1 top Radiator hose availability
If you do fit one of these, be careful of the pressure rating of the header tank filler cap. This was increased in March '63 (as a step to lessen the chance of over-heating) to a 9lb blow-off pressure and a modified top radiator hose was introduced at the same time (Spares Bulletin N.3 relates).
1964 S1 3.8 OTS
1964 S1 3.8 OTS
#3 Re: early S1 top Radiator hose availability
I have this type of hose from Bill Tracy for my xk120 - I should probably add that it's rather hard, and would not expand like (probably) intended.
So, the cap might actually be from the later models...
Tadek
Tadek
Tadek
Jaguar XK120 OTS
Jaguar XK120 OTS
