3.8 inlet manifold gaskets leaking
#1 3.8 inlet manifold gaskets leaking
Hello,
I replaced the 3 inlet manifold gaskets and used the items with article number C 14127/1 from SNGB. All metal contact surfaces were clean and not damaged. Before fiting the gaskets, I coated both sides with black silicone sealant that is approved for the engine/coolant area. After I adjusted the carburetors and warmed up the engine a few times, slight coolant leaks appeared on all three inlet manifold gaskets.
Was it a mistake to use silicone selant? Is it safer to use a non-drying sealant like Hylomar or are these seals to be installed dry? Are Cometic seals maybe the better choice and who offers them? Does a sealant have to be used with the Cometic items?
Thank you for your help
#2 Re: 3.8 inlet manifold gaskets leaking
This is a very common problem irrespective of the type of gasket used and/or whether sealant is applied. It is usually the result of the manifolds "settling" as the engine warms up, and can usually be eliminated by retightening all the manifold to head nuts
#3 Re: 3.8 inlet manifold gaskets leaking
I had exactly this problem on a 4.2 with the combined manifold. I was using the tin gasket. After stripping off the assembly and cleaning up I went back to the fibre gaskets and all was well.
Tim
Tim
#4 Re: 3.8 inlet manifold gaskets leaking
Hallo Christopher,
Retightening the nuts unfortunately did not help.
Tim. What type of sealing material did you use when installing the fibre gasket?
#5 Re: 3.8 inlet manifold gaskets leaking
hylomar is fuel proof, Room Temperature Vulcanizing silicone is not. Fuel might be puddling at the bottom of the ports and cause a leak when coolant gets up to pressure? Cometic are excellent but expensive, although they can be reused several times. Fibre gaskets are better than tin gaskets (which look reusable but are dodgy once the embossing is flattened).
Are you sure the leak isn't from the water rail gaskets or fitting?
If anyone wants a complete 3.8 carb/manifold kit I will advertise it again. Also fits a 4.2 with a bit of work...
#6 Re: 3.8 inlet manifold gaskets leaking
I think I used wynns instant black gasket maker. I’m aware however that should I ever want to remove the manifold then this will make it a right bugger.
#7 Re: 3.8 inlet manifold gaskets leaking
Just fitted a fibre gasket and blue hylomar on a 4.2...works fine no leaks.....Steve
#8 Re: 3.8 inlet manifold gaskets leaking
Suggest you follow the advice from Steve .
#9 Re: 3.8 inlet manifold gaskets leaking
Thank you.
Tim I will try this way. We will see.
Best reagrds
Best reagrds
