Mangoletsi throttle pedal assembly
sulzeruk
#1 Mangoletsi throttle pedal assembly
Post by sulzeruk » Sat Oct 07, 2023 12:28 pm
I recently bought a dark green 1965 fixed head that's on the road as always wanted one. It's been with the previous owner for 34 years and been reasonably well looked after but still needs lots of little jobs sorted on it.
The throttle linkage however is really quite tired and all the ball ends are worn as they've not been lubricated in a long time from what I can see. The car was bought to be used rather than hidden in the garage most of the year so was thinking of fitting one of the Mangoletsi cable kits. Looking for any feedback on them by owners who have fitted them. I find the pedal with the original quite heavy as well.
Alasdair
1970 S2 2+2
1965 S1
1966 S1 2+2
1965 TR4A
#2 Re: Mangoletsi throttle pedal assembly
Post by Heuer » Sat Oct 07, 2023 1:47 pm
Probably the best upgrade you can make to an E-Type! more info here: viewtopic.php?f=9&t=3512
Silk smooth operation and twice the pedal travel so easier to modulate the throttle and you will see an improvement in mpg as a result.
S1 OTS OSB; S1 FHC ODB
sulzeruk
#3 Re: Mangoletsi throttle pedal assembly
Post by sulzeruk » Sat Oct 07, 2023 1:50 pm
Many thanks David, I'll get one ordered up. I am also 6 foot 3 as well so will be able to lower the pedal a bit as it's a bit of a squeeze.
Alasdair
1970 S2 2+2
1965 S1
1966 S1 2+2
1965 TR4A
Airborne62
#4 Re: Mangoletsi throttle pedal assembly
Post by Airborne62 » Sun Oct 08, 2023 12:45 am
I installed the Mangoletsi on my 62 FHC. Huge improvement. I'm 6'2" and needed more legroom. I measured my TR6 pedal positions (which were also identical to my 73 BMW CSi pedals) and lit the torch. Great upgrade.
Airborne62
'62 FHC
sulzeruk
#5 Re: Mangoletsi throttle pedal assembly
Post by sulzeruk » Tue Oct 24, 2023 2:02 pm
I received my Mongoletsi throttle pedal assembly yesterday, looks a nice bit of kit so will be getting it fitted in the enxt while along with a cooling system overhaul and lots of other small jobs.
Alasdair
1970 S2 2+2
1965 S1
1966 S1 2+2
1965 TR4A
Vegard
Norway
#6 Re: Mangoletsi throttle pedal assembly
Post by Vegard » Mon Jan 08, 2024 1:53 pm
The Mangoletsi kit is worth every darn penny!!
68 1.5 FHC, 65 4.2 FHC, 72 MGB GT, 6 Minis, 71 Escort1300GT, 65 BMW Neue Klasse, 62 Volvo P1800 and a 205 GTI
paulsco
#7 Re: Mangoletsi throttle pedal assembly
Post by paulsco » Tue Jan 09, 2024 2:00 pm
Seems to be no longer available on the SNG website?
Robbiee
#8 Re: Mangoletsi throttle pedal assembly
Post by Robbiee » Wed Jan 10, 2024 3:07 pm
What’s the benefit …is it particularly good for LHD cars due to the longer linkage ??
sulzeruk
#9 Re: Mangoletsi throttle pedal assembly
Post by sulzeruk » Thu Jan 11, 2024 2:45 pm
Spoke with SNG, John has retired so they have stoped productions of them unfortunately so no longer available.
1970 S2 2+2
1965 S1
1966 S1 2+2
1965 TR4A
sulzeruk
#10 Re: Mangoletsi throttle pedal assembly
Post by sulzeruk » Thu Jan 11, 2024 3:22 pm
SC parts have one in stock for £1500 if someone is completely desparate.
1970 S2 2+2
1965 S1
1966 S1 2+2
1965 TR4A
#11 Re: Mangoletsi throttle pedal assembly
Post by politeperson » Thu Jan 11, 2024 5:45 pm
I have usen the Mangoletsi assembley, it is great but it is expensive. Being about unobtainable does not help either.
More recently I have used this £90 Sytec duel cable assembly, for rally cars. That is well built too.
You could mount the cable end on a bracket bolted into the two captives in the picture on the bulkhead, above the pedal.
I know it is only part of the solution.
I have used the original pedal and modified the arm to accept the cables.
Then it was a matter of figuring out the other end.
For me it was easy because the Heritage throttle bodies share Weber dimensions.
I am sure I could figure something out for SUs. A nice low rise pivot is in the kit, so It should jut be a matter of adding an arm and ball joint to the lower carb rod.
Too many E types
XK120 SUs
sulzeruk
#12 Re: Mangoletsi throttle pedal assembly
Post by sulzeruk » Fri Jan 12, 2024 11:57 am
I'll maybe look into making something as there is definitely a market for it and my mate has a CNC company with a nice new machine. Also has access to laser cutting as well.
1970 S2 2+2
1965 S1
1966 S1 2+2
1965 TR4A
#13 Re: Mangoletsi throttle pedal assembly
Post by Gfhug » Fri Jan 12, 2024 12:24 pm
For a simple kit that makes use of the existing pedal:
A bracket to take a double cable from the pedal lever
A dual cable attachment to that lever that will go onto the ball without damaging said ball so that the original rod system can be re-instated
A bracket at the airbox or thereabouts to feed cables to the throttle rod
Dual cables, maybe from existing motorbikes
A round clamp that goes around the throttle lever to accept the cables
Noting the differences between early 3.8 engines, the S1 and S2 4.2s
It'll be interesting to see if you can come up with a simple kit at a decent price. Yes, it won't have the finesse or pedal arrangement of the Mangoletsi, but if that is now out of production then there could be a reasonable market for it.
PS, but does it need to be double cable just because that’s what Mangoletsi had?
sulzeruk
#14 Re: Mangoletsi throttle pedal assembly
Post by sulzeruk » Sun Jan 14, 2024 4:49 pm
A double cable is best as it gives an even pull, a single cable will always want to twist and you also have redundancy as well with 2 cables over 1 if 1 decides to break. Also the cost for 2 is not much more compared to 2.
1970 S2 2+2
1965 S1
1966 S1 2+2
1965 TR4A
Hotrod
#15 Re: Mangoletsi throttle pedal assembly
Post by Hotrod » Tue Mar 05, 2024 11:37 am
Help please.
I have bought a kit for my S2 LHD. Long story but I only have the instructions for a RHD conversion. Does anybody have a set of instructions for a LHD? Do you know whether I have to remove the steering wheel to remove the steering column from the original throttle body?
Many thanks
Rod
Rod Evans
1969 S2 DHC LHD
Airborne62
#16 Re: Mangoletsi throttle pedal assembly
Post by Airborne62 » Thu Mar 07, 2024 12:11 am
The shaft just passes through the throttle housing. Not sure you actually need to remove the wheel.
Airborne62
'62 FHC
#17 Re: Mangoletsi throttle pedal assembly
Post by Heuer » Thu Mar 07, 2024 10:48 am
Angus has done the LHD conversion (I did the first RHD one) and being the perfectionist he is he ran the cables along the bulkhead to avoid cluttering the engine view (click to enlarge):
Also this thread may have some useful tips: viewtopic.php?p=27943#p27943
Hotrod
#18 Re: Mangoletsi throttle pedal assembly
Post by Hotrod » Thu Mar 07, 2024 4:52 pm
Many thanks both. I’ve read your thread several times David, indeed it was your comments as to how good this is that persuaded me to take the plunge! I like Angus’ idea of routing the cables. For obvious reasons, I’m very keen to get LHD instructions before I start. Hopefully someone will have a copy…
Thanks again,
Rod
Rod Evans
1969 S2 DHC LHD
Hotrod
#19 Re: Mangoletsi throttle pedal assembly
Post by Hotrod » Mon Mar 11, 2024 3:06 pm
SNGB have kindly sent me a copy of the instructions for a LHD installation. Big thank-you to them. All I’ve got to do now is fit it.
Rod
Rod Evans
1969 S2 DHC LHD
#20 Re: Mangoletsi throttle pedal assembly
Post by Heuer » Tue Mar 12, 2024 10:23 am
Moss Jaguar have their open day on 22 June and Angus's LHD FHC with the Mangoletsi throttle will be on display. Plenty of chance to ask questions and take photos.
