Where does the choke cable go through the firewall on a LHD? It's not mentioned on bulkhead layout diagram, my guess would be in the circle, but the it twists the cable quite a bit
Choke, cable
Topic author - Posts: 189
#1 Choke, cable
Mikael
63 E-Type, 81 XJ6, 03 X-Type, 07 XKR
09 CTS-V
78 Longchamp
Author of "Tuning Made Easy"
09 CTS-V
78 Longchamp
#2 Re: Choke, cable
Hi Mikael
That is the correct hole for the choke cable and it gives a very straight run from lever to choke on carbs. I suspect that you may have installed the choke lever on the left of the centre panel, rather than the right
'78 Land Rover Series 3 109
#3 Re: Choke, cable
Hhmm, no, the choke lever mechanism is one of the few things the seller didn't take apart, I only oiled and replaced cable. It's smooth enough, so I'll leave it
Mikael
09 CTS-V
78 Longchamp
09 CTS-V
78 Longchamp
