I have the parts below and can make double flanged pipes. But can't find a picture of routing. Where exact are brackets attached, and picture of pipe routing would be great. Remember LHD.
Clutch pipe/hose/bracket routing LHD
Topic author - Posts: 187
#1 Clutch pipe/hose/bracket routing LHD
Mikael
63 E-Type, 81 XJ6, 03 X-Type, 07 XKR
09 CTS-V
78 Longchamp
Author of "Tuning Made Easy"
09 CTS-V
78 Longchamp
#2 Re: Clutch pipe/hose/bracket routing LHD
Not the best photo, but should give you an idea:
- top L shaped bracket is mounted on the inner, lower frame setscrew
- the small bracket is mounted on one of the screws mounting the block to the gearbox bracket
BTW, they are both the same colour as the radiator brackets (blueish).
Tadek
Tadek
Tadek
Jaguar XK120 OTS
Austin-Healey 100 BN2
Jaguar XK120 OTS
#3 Re: Clutch pipe/hose/bracket routing LHD
Tadek
Jaguar XK120 OTS
Jaguar XK120 OTS
#4 Re: Clutch pipe/hose/bracket routing LHD
Perfect Tadek
Mikael
09 CTS-V
78 Longchamp
09 CTS-V
78 Longchamp
