Hello forum, I need to replace the headlights on my car. I have a pair of Marchal Ampliluxes 7” that are great lights but I’ve have not seen them installed on e types. Do you know if these were ever used or installed on e types?
Thanks for your comments !
Pablo
Marchal Amplilux headlights
#1 Marchal Amplilux headlights
Pablo
1956 Mercedes 190 SL
1973 Porsche 911 T targa
1969 Porsche 912
1970 Alfa 1300 GT junior Scalino (sold)
1966 Jaguar e type FHC (unfortunately sold)
1967 Jaguar e type OTS 1.25 series
1976 Toyota FJ40 (I learned to drive with this one)
1969 Porsche 912
#2 Re: Marchal Amplilux headlights
The Factory fitted Lucas headlamps although when cars were shipped to the US sealed beam were mandated; they were usually GE headlamps. Marchal Ampilux were an after market upgrade for many cars in period but if you have a S1 bonnet they may not fit. This is because the buckets have a slanted back to clear the front tyres.
Here is a comparison of Cibie vs Wipac to illustrate the problem - only the Wipac fit:
Cibie vs Wipac:
The Cibie are better headlamps but will not fit the S1. You need to measure from the rim (not the attachment points). It has to be less than 3". If you have an S1.5 or S2 bonnet there is no fitment problem
Cibie vs Wipac:
S1 OTS OSB; S1 FHC ODB
#3 Re: Marchal Amplilux headlights
Thank you very much David, I’ll measure them as you mention. I’m not absolutely sure about installing the Marshals as they are flat on the front instead of curved as the original headlights are not sure how that is going to look on the car. I have not been able to find a picture of how these Ampliluxes look on an etype
Pablo
Pablo
Pablo
1969 Porsche 912
1969 Porsche 912
#4 Re: Marchal Amplilux headlights
Looking at photos I doubt they will fit an S1 E-Type bonnet as they are very big due to the double reflector design:
#5 Re: Marchal Amplilux headlights
Thank you David, they will not fit. I’ll keep looking for an original set of Lucas 7” and leave the Marshals for an early 911.
Thank you very much, you saved me a headache,
Pablo
Pablo
Pablo
1969 Porsche 912
1969 Porsche 912
#6 Re: Marchal Amplilux headlights
Hella H4 e code fits.
They also have the flat lens. Really don't notice it unless you look closely.
I do have a SI with covered headlamps so they are not obtrusive.
You have exposed lamps?
Layne
Car #876005, 62 OTS
Car #876005, 62 OTS
#7 Re: Marchal Amplilux headlights
Hi Layne, my car is a late series 1 with open headlights. I’m in the process of restoring it. All mechanicals are almost done and will start with paint pretty soon.
Pablo
Pablo
Pablo
1969 Porsche 912
1969 Porsche 912
