Fitting the badge bar into the nose of the bonnet - how?
ChrisC
#1 Fitting the badge bar into the nose of the bonnet - how?
Post by ChrisC » Wed Sep 28, 2011 2:09 pm
Okay - I have to ask because I am going nuts with frustration...
I have both front bumpers fitted slightly loose so that i have a little bit of play.
I have the small curved end pieces fitted to the over riders.
The badge bar can be located into those curved end pieces but I will be darned if I can work out how to do the securing bolts up...
Whats the secret please?
If I dont hear back today - i will remove the small curved piece from the over riders, bolt them to the badge bar and then try to rebolt them back onto the over riders... is that the secret? Darn fiddly if it is.
Thanks all
1964 FHC 4.2
Mark Gordon
Post by Mark Gordon » Wed Sep 28, 2011 2:42 pm
If you don't get a reply before I get home, I'll check to see how my badge bar is attached. Unfortunately, that will be around 1100 PM on your side of the pond.
daverawle
Post by daverawle » Wed Sep 28, 2011 2:45 pm
Maybe not the recommended way but I bolted the whole lot together and fixed it to the car in one piece. You need a helper to support the other end so as not to fracture the motif bar.
1963 OTS
ChrisC
Post by ChrisC » Wed Sep 28, 2011 3:02 pm
Thanks Mark - I know how it is attached - i just cant do the bolts up because there is no room...
Dave's idea would work but fitting both bumpers at once along with the badgebar is not something I can realistically do on my own :(
They cant have done it that way in the factory surely...
1964 FHC 4.2
kingzetts
Post by kingzetts » Wed Sep 28, 2011 3:30 pm
I recall that as being a pretty fiddly job. I found the problem was that there is more clearance around the bolt heads when they are nearly done up than there is when they are first started due to curvature of the nose of the bonnet aperture. With a short 1/4" drive socket and slim extension bar I could get the socket on the bolt heads when they were slightly loose, but could not get the bolts started.
I think what I did was detach one of the over-riders (one bolt into the back of the over-rider from behind the bumper), loosen the other one, attach the bar to the back of the short "horn" projecting from the loosened overrider and do the bolt most of the way up but still allowing some movement, then attatched the bar to the other horn on the removed over-rider, again slightly loosely, then refitted the other over-rider to the bumper and then tightened everything up.
Worth making sure all the bolts involved, and their captive nuts etc, are clean, undamaged and lightly oiled so they screw in and out easily by hand before you start. You don't want to have to use tools to get these bolts started.
John '62 S1 OTS (now sold)
ChrisC
Post by ChrisC » Wed Sep 28, 2011 3:58 pm
Ah.... I *like* that...
Yes of course.... the over riders are held on with one bolt and are MUCH easier to take on and off... I will give that a go tonight. Many thanks
1964 FHC 4.2
Post by 1954Etype » Wed Sep 28, 2011 4:23 pm
ChrisC wrote:Thanks Mark - I know how it is attached - i just cant do the bolts up because there is no room...
Why not? Sub assemble bumpers then two people to fit. Less chance of damaging the paintwork possibly.
ChrisC
Post by ChrisC » Wed Sep 28, 2011 6:53 pm
Yahooo.... thankyou Kingzetts... a matter of moments and the over-riders are off... loosly bolt the badgebar to both over riders and carefully replace the assembly.
insert and do up the over rider bolts, tighten up the badge bar bolts. Job Done.
Nice. So happy. THIS is the way they must have done it in the factory. :lol:
1964 FHC 4.2
vikla
#9 badge bar fittings
Post by vikla » Mon Feb 06, 2012 5:25 pm
Hi, I 'm just sorting out my badge bar.
To mount the bar to the horns the suppliers offer part n. C24792. This is actually 2 bolts joined 'head to head' by piece of a rubber. See http://www.ebay.co.uk/itm/JAGUAR-E-TYPE ... 484331f4ba
I can't understand how to use these parts. If you screw one end into the threaded hole on the horn then put the badge bar on the other end fixed by a nut it looks all wrong - the bar doesn't fit into the horns properly and wobbles a lot. If you fit the bar into the horns with the part acting as a bolt the rubber bit is doing nothing and you get a chunk of the thread sticking out behind the bar.
So what's the point of the part?
Can't you just use a bolt with a rubber washer either side of the hole on the badge bar end?
S1 4.2 FHC 1966
kingzetts
Post by kingzetts » Mon Feb 06, 2012 5:50 pm
The 3.8 parts catalogue has the motif bar held into the bumper horms with a bolt, which is how mine is secured.
The 4.2 parts catalogue does indeed show a rubber bobbin in place of the bolts, but since the bumper horms and the motif bar are the same part numbers in both cases, there is no reason why you can't use a bolt if you prefer.
I surmise that as the motif bar is a relatively fragile item and easily cracked if the bolts are overtightened or it is stressed while assembling, the factory moved to the rubber bobbins to reduce the risk of breakages in service. Also, as both I and Chris found, it is a bit tricky to attach the motif bar using bolts and maybe the bobbin approach avoids having to remove one of the overriders to do so.
Post by Heuer » Mon Feb 06, 2012 5:57 pm
I opted for the rubber bobbins method to avoid fracturing the motif bar through vibration. The bobbin attaches to the bumper horn and the motif bar to the the bobbin. Mine looks OK and there is indeed movement in the bar if you apply pressure to it. I did have one bobbin fail on me some years ago but I think that was down to poor fitting. You need to make sure the bobbins are not under any stress after fitting the motif bar so don't force anything.
S1 OTS OSB; S1 FHC ODB
vikla
#12 badge bar bobbins
Post by vikla » Mon Feb 06, 2012 7:00 pm
Interesting that I now see the official parts list gives item BD24448 as the bobbin, rather than C24792.
The parts suppliers don't offer the former item, however the latter item is used to support the petrol pump on 4.2 cars. So maybe the suppliers think they are very similar.
As said previously when I assemble the whole lot as David suggests the bar is not going far enough into the notch area in the horns as it is clearly designed to do.
Also the C24792 bobbins are quite flimsy with one of my bolt heads already coming loose in the rubber after tightening it up a bit.
S1 4.2 FHC 1966
Post by abowie » Mon Feb 06, 2012 11:50 pm
I did this last weekend. Mine had originally been fitted with the C24792 bobbin but over time the rubber had perished leaving the bolt in the overrider and inaccessible. I just took off the whole bumper leaving the overrider intact. The bobbin bolt was badly rusted in and needed drilling and removing with a screw extractor. I then refitted the new C24792 bobbin and reinstalled the bumper. Rinse and repeat for the other side. Without the drilling it would have taken under half an hour.
vikla
#14 finished job
Post by vikla » Wed Feb 08, 2012 9:23 am
I have now finished putting it all together.
As said before it is easiest to assemble the 2 over-riders and the badge bar together and then offer the whole assembly up where it is fixed using the bolt for each over-rider.
I initially started using the bobbins however on one of them, one of the 2 bolts comprising the bobbin became very wobbly and was clearly not secure.
So I ripped both bolts from the bobbin and just used these to secure each end of the bar to the horns. To make it have a bit of flexibility I used a rubber washer either side of the holes in the ends of the bar. In my case I cut up rubber grommets of appropriate size.
As a result I am very pleased with the end result because the bar now goes right into the cut outs on the horns and is very secure with no chance of failure as can clearly happen when using the bobbins.
On reflection I think the bobbins I have (quite new) are of poor quality because the heads of the bolts they are made from have only about 1mm of rubber around them and therefore can easily come apart when the bobbin is tightened up. I cannot imagine that this is how the original part would have been made and also as said previously they are not the original part as listed in the Jaguar parts list.
S1 4.2 FHC 1966
Post by abowie » Thu Feb 09, 2012 5:03 am
The bolts I removed had a round flat head the same diameter as the rubber, and perhaps 3mm thick.
rfs1957
#16 Re: Fitting the badge bar into the nose of the bonnet - how?
Post by rfs1957 » Sat Apr 07, 2018 11:22 am
Anyone looking around at this topic might like to look here too, both being relevant and helpful.
viewtopic.php?f=4&t=12039
64etype
#17 Re: Fitting the badge bar into the nose of the bonnet - how?
Post by 64etype » Sat Apr 07, 2018 2:32 pm
The trick for me was to use Allen head screws and a short extension.
Eric
