rain-water filling the footwells!!
#1 rain-water filling the footwells!!
hi, firSt timer on this forum but looks like a good place to figuring out some issues i have on my 65 series 1 FHC. Just returned from 1500 mile trip which started in the most unimaginable rain we had been having here over some time. dodged landslides, pot-holes road closures over first two days , but could not avoid the driver and passenger footwells filling with water!! 1-2 inches!! probably squeezed 5-7 litres each time we stopped. !! saw a little water coming in over the sills and figured it was not draining from door top drain quick enough and spilling over(being forced over whilst driving) but this was just too much for any rain coming down and thought it had to be more likely forced up from underneath(behind wheels??) as it stood in pouring rain for some time and didn;t let in any water, got to thinkg it was being forced in . can anyone suggest where this problem lies? i wash the car and nothing comes in.. had body restoration couple of years back and had it back to repairer who found nought back then. !!!! thanks
Firstly you need to check the door drains are clear and that the rubber door seals do not cover them or force the water over the sills, although you should notice this happening. Biggest culprit is usually the carpet fixings which are plastic 'sockets' forced into holes in the floor. The carpets are retained by plastic plugs which go through them and into the sockets. It is quite easy for the sockets to be lifted out of place during use so leaving perfect apertures for water ingress. Easy to check!
S1 OTS OSB; S1 FHC ODB
thanks heuer for your supporting reply. i checked the floor pan for carpet plugs/sockets and none found!(but thought if it came in via them, it would also drain, which it didnt). anyway, i decided to search the data base here and found a thread from 2008 which highlighted the 'door drain ducts'. so when i checked i see my car doesnt have them!! seems that probably panel shop didnt re-install them! anyway thats an arguement i may have to have, but in meantime have emailed SNG for parts and take it from there. so again. thank you, and lets hope this is the cure.. back to lovin my E again
warren
warren
received message today that SNG Barrett do not stock the Drain ducts for the doors. does anyone have suggestions for other suppliers of e tpye panel parts? thanks
65 S1 FHC
They are easy enough to fabricate - just copy the one in the picture you found. They are supposed to butt up against the door seals which should have cut-outs to accommodate them but they will work without them. When you say you could not find any carpet plugs/sockets do you mean there are no holes in the floor pan to accommodate them or the holes are there and unfilled?
heuer, there was no holes. my carpets have only just sat there(very annoying as they slip). yesterday i called the guy who repaired the body some yrs ago and explained the situation. he has asked me to bring it in and he will fab & fit them(although he questioned that they would allow so much water in) he said the mark 2 had similar ducts and will use one there as template.
by the way, overnight I heard from Martin Robey & Hutsons who have the parts for future reference..
Hopefully i can soon update here on a succesful fix, meanwhile Thanks to all for the support. regardswarren
65 S1 FHC
#7 rain water filling the footwells
Hi Warren,
I had the same problem some years back.
First check your doorseals. The front edge seal is particularly important. Does it run the full length of the door?
If it's good (or even if it's not) the most likely problem is that you've got a gap between the bottom of your windshield and the car body. When you wash water sort of runs off. When you drive the wind blows water straight back, up the bonnet, through the gap and onto your feet.
Ever since plugging that gap my feet have been dry.
Best wishes,
Larry
Best wishes,
Larry
Larry Wade
62 OTS 877842
La Canada, California, USA
62 OTS 877842
Hi Larry, thanks and will now go check those door sill rubbers that they do indeed run the length of the sill... but could you please expand on that area"between wind shield and the car body" in more depth please. without pictures, i,m at a loss to comprehend ..( mis-spent youth is my excuse)
65 S1 FHC
#9 rainwater filling the footwells
Hi Warren,
Along the bottom edge of the windshield is a chrome molding.
Between the body and that chrome there can be a gap. This is especially true where there is a kind of valley that starts on the inside of the headlights/wheelwell bump. Water gathers in this valley and runs uphill into the base of the windshield.
If the gap is totally plugged the water is then blown away from the sides of the car. However is there is a leak there the water will go straight back into the passenger compartment and run down into the footwell.
I'd attach a picture but I don't know how to. If the above description is not clear feel free to email me at lwade@caltech.edu and I'll send you a couple closeups.
Larry
Larry
Larry Wade
62 OTS 877842
62 OTS 877842
update.....
got the E back home today from fabricator who made up the drain-ducts and placed them(4 each side) to marry up with drain holes in doors. He tested them prior to fitting and had water running into car from sills at stand-still after some minutes. No water after fitting with same test and was fortunate to have rainy day to test run the car.. still no water. dadaaaa! maybe fixed and seems to have cured a draught that was coming in from front area of si;ll. anyway, roll on a miserable wet day for me to give it a good work-out. i will post the result. thanks to all.
warren
warren
65 S1 FHC
Hi just found where i bought mine from. Thames valley repairs limited Tel 01628 781717 saw them in jaguar world.Perfect fit used self tappers instead of pop rivets easier to remove should you want to.
Adam
Adam
thanks adam, but repairer made some up and only charged minimal to fit . he pop riveted but of course couldn't spot weld so used a silastic to seal the verticals to door. still no rain to test it.....c,mon!!
65 S1 FHC
#13 Water leaks on FHC
I too have a FHC and use it in all weather. Tracking down leaks can be tricky but one discovery blew me away. The water was coming in through the two screws that hold down the B post just behind the door.
It was just bleeding in and running onto the carpet behind the seat and soaking into the floor carpet under the seat.
A bit of sealant on the threads of these screws......problem solved.
Jon Gant
Jon Gant
Jon Gant
