COMPETITION DEPARTMENT FIT
Topic author - Administrator
#1 COMPETITION DEPARTMENT FIT
Harold Lang contacted me and suggested we try and document the modifications the Competition Department made to various cars from the Lightweights to customer 'special orders'. Harold has kicked things off with the following:
Car number 860630
Car number 860630
S1 OTS OSB; S1 FHC ODB
Car number 1E1139
This was one of a pair of identical competition OTS cars ordered by Mr Robert James Duncan but he was killed in the first one before he had taken delivery of 1E 1139 on 1st April 1965. The Comp Dept modifications are fully listed on the original dated invoice from the Distributor in Lurgan:
Factory upgraded brakes:
Reinforced brake hoses:
Rear brake air cooling scoop:
Secondary cooling scoop at rear held on by Cheney clips:
Competition wire wheels (x4) painted in their original dark grey metallic:
Front brake cooling ducts:
Early 3.8 breather outlet:
Advance vacuum cut off valve:
Factory fitted intake trumpets (not red originally):
Remote diff breather in boot:
Plug caps and conduit:
Car number S850667
Lightweight upper swivel:
#4 Re: COMPETITION DEPARTMENT FIT
Harold Lang sent me these. An original 3.8 E-Type Velocity Stack, Jaguar part number XK.4520 similar to the red painted ones in the photos above.
Just shows you how the currently available stacks are the wrong shape for the XK engine. Jaguar knew what they were doing.
#5 Re: COMPETITION DEPARTMENT FIT
"Car no. S850667
Engine no. V682558P
3,781cc DOHC All-Alloy 6-Cylinder Engine
Lucas 2MDC6/M Fuel Injection
293bhp at 5,750rpm
4-Speed Manual Close-Ratio Gearbox
4-Wheel Independent Suspension
4-Wheel Disc Brakes – Inboard Rear
*One of the absolute best and most original examples of the 12 Lightweight E-Types
*Preserved by just 3 owners from new while accumulating less than 4,000 miles
*Championship winning racing history in period
*Documented in numerous books and with build sheets, factory correspondence and period photographs"
Currently for sale by Bonhams:
Engine no. V682558P
293bhp at 5,750rpm
#6 Re: COMPETITION DEPARTMENT FIT
Marvellous detailed images - excellent that these original factory developments have been captured...
Chassis no: 860403
DOM - 11th April 1962
#7 Re: COMPETITION DEPARTMENT FIT
A very good set of pictures showing the original "STD" Lightweight features that would have been turned out to customer cars in period.
The picture set loaded in July 2015 has an out of place photo of the front suspension, which I don't think is of the Bob Jane Car.
The give away is the triangular cut out in the upper wishbone, this feature was introduced on the Coombs car first as part of a package of developments, later applied to the Linder Car in 1964, so only two cars originally.
The suspension also has more modern tweaks not shown in the latter pictures.
Bonhams also clearly don't know what a Jaguar Engine number should look like either, the number stamped adjacent to the front timing cover/ Dynamo is a strange format.
The diff breather is unique to Lightweights as well, but that format is usually used for the gearbox.
It will be very interesting to see what the car achieves at the auction.
I very much like the retained wear and tear "patina" as well. Someone should be credited for turning the car out this way.
Michael
1961 OTS LWE, 1965 OTS, 1966 FHC.
#8 Re: COMPETITION DEPARTMENT FIT
Some original LWE parts:
Dry sump:
Fuel tank:
Fuel tank supports:
Radiator:
Header tank:
Seat belts:
Perspex side windows from 9023 DU (S875027), when raced in 1963:
Suspension uprights and anti-roll brackets
Clutch plate:
Hubs and drive shaft:
NOS Brake discs with Jaguar part number:
Calipers:
Resonators:
Camshafts:
Competition wheels from YRP 99 (S850020):
Miscellaneous parts:
Various shock absorber spacers, fuel tank take off and original mallet:
Miscellaneous parts, used and unused coils, original plug leads, radiator blind mechanism, etc.
Qvale LWE door mirror and cowling used at 1963 Sebring 12 hours race:
Dunlop alloy wheels:
Original Dunlop alloy spare wheel with tyre for Phil Scragg LWE PS 1175:
Provenance: From the John Mayston-Taylor's Collection currently for auction at https://www.jaguarautomobilia.com/auction/
Many thank to Bud Marston for bringing these to my attention.
Dry sump:
Fuel tank:
Fuel tank supports:
Radiator:
Header tank:
Seat belts:
Clutch plate:
Calipers:
Resonators:
Camshafts:
#9 Re: COMPETITION DEPARTMENT FIT
Harold Lang sent me these:
