Hi all!
If you'd have an opportunity to give a piece of a advice, would appreciate
What dampers, front and rear, you would recommend for an E-type (S1), if we're looking at a harder, than stock, option... at SNG Barrat I can see, that for the front they offer KONI FRONT SHOCK ABSORBER / DAMPER (PRODUCT CODE: C20011KON) and also adjustable option of GAZ adjustable dampers (RODUCT CODE: C20011GAZADJ).... But I did not find yellow Koni sport option (Their sports series usually comes in yellow color)... what do you suggest? Also, do they need special springs? Same question for rear...
And second question is, looking for a set (4) of crome wire wheels, 15 * 7J (wide wheels), maybe someone got a set in great condition for sale? pls PM
Thank you!
dampers and wheels advice
Topic author - Posts: 54
#2 Re: dampers and wheels advice
I have 3 series 1 E Types.
I have tried all of the available options; Boge, Gaz and Koni.
In my view the cheapest option, that is standard Boges front and rear, and reusing the original rear springs that came with the car, gives the best ride.
You do not want to make the E Type suspension stiffer, especially at the rear.
#3 Re: dampers and wheels advice
Thank you mate, so you suggest the stock option without any problem and it is stiff enough
I am asking as we have a Koni now, and I was wondering if stock is better
#4 Re: dampers and wheels advice
Koni do not suit the E-Type and you are paying a premium for adjustability that you will never use. I got rid of Koni"s on both my car's and replaced them with Boge; the ride and handling are much improved.
S1 OTS OSB; S1 FHC ODB
#5 Re: dampers and wheels advice
Dear Heuer, thank you so much, this is important info for me
