Brake fluid bulkhead decal
Monkeyfinger
#1 Brake fluid bulkhead decal
Post by Monkeyfinger » Thu Nov 28, 2019 2:22 pm
Does anyone still have an original warning sticker/decal on the bulkhead? I'm making up a replacement, and I need to know the size of the rectangular box around it, so I get the correct end result. My car had the 'squarer' style as per the attached photo of the remnants that I had. The height of text would be useful if anyone can help. Some of the replacements I've seen are not a great match for the original.
- 1969 Series 2 OTS
Monkeyfinger
#2 Re: Brake fluid bulkhead decal
Post by Monkeyfinger » Fri Feb 14, 2020 2:30 pm
Not many replies here! Anyway, I've now produced a label design as attached, which is a photographic copy of original Series 2 style, rather than a modern approximation. I do still need help from someone to confirm the length and height of the label so that I can get the proportions correct. I'm guessing the label is around 60mm long, but I'd like to get this correct. If anyone is interested in one of these, then let me know.
- 1969 Series 2 OTS
#3 Re: Brake fluid bulkhead decal
Post by Heuer » Fri Feb 14, 2020 4:34 pm
Jaguar was still using imperial measurements back then so get the size in inches and I am guessing it will not be in minor fractions. Don't have access to an original so can't help there I'm afraid.
S1 OTS OSB; S1 FHC ODB
Monkeyfinger
#4 Re: Brake fluid bulkhead decal
Post by Monkeyfinger » Fri Feb 14, 2020 6:38 pm
Good shout - maybe 2 1/2 inches.
- 1969 Series 2 OTS
#5 Re: Brake fluid bulkhead decal
Post by Heuer » Fri Feb 14, 2020 10:04 pm
If so you can use the horizontal axis size to calculate the vertical size from your photo. It will always be an imperial fraction so easy to work out.
Bfastr
#6 Re: Brake fluid bulkhead decal
Post by Bfastr » Sat Feb 15, 2020 2:03 am
my very original and beat up decal is 2 inches wide and 1 1/8 inches high
Bob F
69 S2 E-type OTS LHD
Monkeyfinger
#7 Re: Brake fluid bulkhead decal
Post by Monkeyfinger » Sat Feb 15, 2020 9:09 am
Perfect Bob, thanks. Looks like it was a perfect Imperial size, as advised.
- 1969 Series 2 OTS
Monkeyfinger
#8 Re: Brake fluid bulkhead decal
Post by Monkeyfinger » Thu Feb 20, 2020 5:52 pm
Final version of label now complete. I've also tried different levels of ageing on these, since it should look more in keeping with my car. For info, printed on 100gsm photo paper and then lacquered for protection. I think a very close match for the original and way better than any reproduction that I've seen. Thanks again to Bob for the size info - these are 2 x 1 1/8".
- 1969 Series 2 OTS
AshM
#9 Re: Brake fluid bulkhead decal
Post by AshM » Fri Feb 21, 2020 1:55 pm
Are you selling these Richard?
Would be keen to buy one off you.
Ash
Series 2 FHC 1970
1R 20607
Monkeyfinger
#10 Re: Brake fluid bulkhead decal
Post by Monkeyfinger » Fri Feb 21, 2020 3:12 pm
Hi Ash, I can do. Send me a PM and we can sort something out.
- 1969 Series 2 OTS
Richardhealey
#11 Re: Brake fluid bulkhead decal
Post by Richardhealey » Fri Feb 21, 2020 4:25 pm
Hi Richard,
Maybe we need a version that runs along the lines of ‘...brake system is filled with silicone brake fluid....’
I’ll get my coat...
Monkeyfinger
#12 Re: Brake fluid bulkhead decal
Post by Monkeyfinger » Fri Feb 21, 2020 5:04 pm
Well, it's funny you should say that. I am always open to requests...
- 1969 Series 2 OTS
Monkeyfinger
#13 Re: Brake fluid bulkhead decal
Post by Monkeyfinger » Wed Feb 26, 2020 9:14 am
Ash, reply sent...
- 1969 Series 2 OTS
Monkeyfinger
#14 Re: Brake fluid bulkhead decal
Post by Monkeyfinger » Wed Feb 26, 2020 3:29 pm
If anyone wants these, just send me a PM and we can get it sorted. Also available as a silicone fluid option for the modernists out there...
- 1969 Series 2 OTS
Richardhealey
#15 Re: Brake fluid bulkhead decal
Post by Richardhealey » Wed Feb 26, 2020 9:05 pm
:drinkingcheers:
AshM
#16 Re: Brake fluid bulkhead decal
Post by AshM » Fri Feb 28, 2020 2:28 pm
Arrived safely today Richard - they look really good. Fitting tomorrow - will post a picture.
Just confirming mine should be in the same place as the picture in an earlier post - on bulkhead above the heater box.
Original 1970 RHD.
just thought I should be 100% sure!!
thanks
Ash
Series 2 FHC 1970
1R 20607
Monkeyfinger
#17 Re: Brake fluid bulkhead decal
Post by Monkeyfinger » Fri Feb 28, 2020 3:17 pm
Yes, as shown above. The position is a little random from the factory, but in that general area.
- 1969 Series 2 OTS
AshM
#18 Re: Brake fluid bulkhead decal
Post by AshM » Fri Feb 28, 2020 5:50 pm
:thankyouyellow:
Series 2 FHC 1970
1R 20607
Monkeyfinger
#19 Re: Brake fluid bulkhead decal
Post by Monkeyfinger » Fri Feb 28, 2020 6:05 pm
Here's another one...
- 1969 Series 2 OTS
AshM
#20 Re: Brake fluid bulkhead decal
Post by AshM » Sat Feb 29, 2020 9:43 pm
Fitted and looks great Richard.
Thanks very much.
Ash
Series 2 FHC 1970
1R 20607
