Removing the rear side marker lights
#1 Removing the rear side marker lights
I'm looking to remove the rear marker light on my american s2 FHC and wonder if anyone knows of a supplier of blanking plates to fill the holes left after the lights are removed?
TIA,
TIA,
S2 4.2 FHC
Ford F100 pickup
KTM 525 XC
BMW C400x
"You only live once, but if you do it right, once is enough..."
Ford F100 pickup
KTM 525 XC
BMW C400x
#2 Re: Removing the rear side marker lights
One enterprising owner at Bicester a few years ago simply used some black masking tape over the hole. He had a black car and I didn't even notice he'd done it until he pointed it out. If you get some very thin vinyl and spray that body colour, then you'll achieve the same for next to no cost.
There are no blanking plates for this application. The two common alternatives are to weld or bond a metal plate to the inside and paint body colour or fit aftermarket side marker lenses in clear or smoke grey colour or any other colour you like if you so chose. This makes for a better colour match and so hides the side markers better.
The xj12 side repeaters are thinner than the etype ones - same Lucas part number. This makes them less obtrusive than the bulky etype ones.
- Attachments
- Image2.jpg (133.72 KiB) Viewed 4505 times
#3 Re: Removing the rear side marker lights
The holes are tiny, just mig them up!
Too many E types
XK120 SUs
Too many E types
XK120 SUs
#4 Re: Removing the rear side marker lights
I removed mine on my XKE S2 FHC when it was returned to full UK spec, just get them welded up for the best result.
Mike,
1970 S2 FHC 2R28165
1970 S2 FHC 2R28165
#5 Re: Removing the rear side marker lights
Thank you for all the replies. The fix appears to be easier than I thought.
S2 4.2 FHC
Ford F100 pickup
KTM 525 XC
BMW C400x
Ford F100 pickup
KTM 525 XC
BMW C400x
#6 Re: Removing the rear side marker lights
Does the petrol tank have to come out to get to the left hand marker - especially if welding around there?
1970 S2 2+2
1970 S2 2+2
#7 Re: Removing the rear side marker lights
No.
Unless it is leaking!!
Too many E types
XK120 SUs
Too many E types
XK120 SUs
#8 Re: Removing the rear side marker lights
Marek, can I ask where I can purchase a pair of the clear lens from?
TIA,
TIA,
S2 4.2 FHC
Ford F100 pickup
KTM 525 XC
BMW C400x
Ford F100 pickup
KTM 525 XC
BMW C400x
#9 Re: Removing the rear side marker lights
From me - I can make you a custom set if you like.
Send me an email or a pm.
#10 Re: Removing the rear side marker lights
Thank you, email sent.
S2 4.2 FHC
Ford F100 pickup
KTM 525 XC
BMW C400x
Ford F100 pickup
KTM 525 XC
BMW C400x
#11 Re: Removing the rear side marker lights
Thank you Marek, great service and quality lens.
S2 4.2 FHC
Ford F100 pickup
KTM 525 XC
BMW C400x
Ford F100 pickup
KTM 525 XC
BMW C400x
#12 Re: Removing the rear side marker lights
As the paintwork on my car was/is nice, I have used little black plastic plugs as a temporary solution until they can be welded properly up and painted. Being a darker colour they don't stand out too much...
1969 S2 FHC (Opalescent Maroon) 1R26120
"The older I get, the faster I was"
#13 Re: Removing the rear side marker lights
Dear Dave
I also have a set in smoke grey colour - that might suit even better given your car is grey.
#14 Re: Removing the rear side marker lights
Thank you for the offer, however the car is Ascot Fawn so the clear work best.
S2 4.2 FHC
Ford F100 pickup
KTM 525 XC
BMW C400x
Ford F100 pickup
KTM 525 XC
BMW C400x
