Missing at high revs under load
#21 Re: Missing at high revs under load
Mike
Angus got my dizzy rebuilt and got the Pertronix kit plus coil from him as well. So it should have worked properly. Don't know about the spark plugs, I'll have to look at that.
#22 Re: Missing at high revs under load
This is turning out to be very frustrating, everything I do seems to make a difference immediately and then the problems come back again. Have replaced the fuel and air filters. Plugs, leads, and coil. It is definitely more drivable now as it had deteriorsted to the point that it was pretty much missing all the time. Now it’s pretty good under load but there is a miss at cruise and it some rev ranges. The tacho sits pretty smoothly even when it is missing.
I think I am at the end of my ability, it’s going to the mechanic
Sydney Australia
Current
Jaguar Red Series 2 2+2 XKE 1969
Jaguar Italian Racing Red F-Type S 2014
Jaguar XJ6 Vanden Plas dark green 1985
Jaguar XJS V12 Silver 1987
Previous of interest
Jaguar XJ6 Sovereign series 3
MGA 1959
Current
MGA 1959
#23 Re: Missing at high revs under load
Are you using the reproduction Champion plug caps? These fail in exactly the way you describe.
#24 Re: Missing at high revs under load
No, standard style and brand new leads.abowie wrote:Are you using the reproduction Champion plug caps? These fail in exactly the way you describe.
Sydney Australia
Current
MGA 1959
Current
MGA 1959
#25 Re: Missing at high revs under load
copper leads or silicone?
#26 Re: Missing at high revs under load
Silicone
Sydney Australia
Current
MGA 1959
Current
MGA 1959
#27 Re: Missing at high revs under load
Thanks all, Murphy’s law applies, it’s always the last thing you get to. It was the distributor cap.
Purring like a kitten again.
Sydney Australia
Current
MGA 1959
Current
MGA 1959
#28 Re: Missing at high revs under load
Interesting.i had a repro dizzy cap that the spring-loaded center button broke cleanly off, right at the plastic. The car still ran, but had a random miss. Took me a bit of time to find, because the cap was only a couple of weeks old.AnD3rew wrote: It was the distributor cap.
Bob t
LHD '69 OTS. (Former) basket case
#29 Re: Missing at high revs under load
That is interesting, because when you looked closely at mine it looked like the rotor had become misaligned in some way and had scored the inside of the cap.
Sydney Australia
Current
MGA 1959
Current
MGA 1959
#30 Re: Missing at high revs under load
Mine wasn't cured first time but...
After replacing the Pertronix with points, the high speed was cured but low speed became terrible. Found the timing was out and was sorted. It now runs fine. Just goes to show the old ways are sometimes the best.
Now move on to the next problem
#31 Re: Missing at high revs under load
Now the distributor cap is fixed and it has new plugs, leads, distributor cap and rotor, and coil it is running beautifully, a little lumpy at idle but I can live with that. But The Pertronix doesnt seem to be causing the problems. I now have strong clean smooth power all through the rev range.
Sydney Australia
Current
MGA 1959
Current
MGA 1959
#32 Re: Missing at high revs under load
I think that the lumpy idle is pretty much par for the course with the 4.2.
The cars are nice when they're running well though.
