At low speeds I have always noticed a bit of noise coming from the rear brakes.
Apply the handbrake and the noise almost disappears.
Over the last couple of days it got pretty noisy, so I took the car up to my friendly Mercedes Garage a few hours ago. They stuck it on the lift and we had a look with a torch.
Well, 3,000 miles ago I had 4 handbrake pads. Now I have 3.1!
One was worn down completely. The rest like new. Picture below for comparison.
The question is why? Cant say I have touched them, they have been on and off, but cant say I have given them much thought.
As it was 5.15pm and the Mercedes garage didn't have any Jaguar pads, Nigel unbolted the two bolt /pins holding the RHS handbrake mechanism on, undid the split pin and we removed the whole unit in a couple of minutes from underneath.
Nice quiet drive home, albeit with no hand brake.
I must admit, I didn't even think about the fact the handbrake calipers might have a ratchet mechanism inside, when I dropped the IRS and did everything else. Seems it might seize up on a 50 year old car.
So I removed the case and had a look, revealing the ratchet mechanism, all in lovely unworn condition but caked in dry grease.
So, I shall clean it up and re grease it after I have purloined new pads. I shall lubricate the other one with grease as well.
I am just not quite clear to me what the mechanism is that pulls the pads away from the disc.
I did notice that a small pin was missing from the hole to the bottom of this picture in one caliper half. I think it must lock the adjusting screw. Maybe that was the issue? The pin was missing all along?
