Jaguar E Type Series 2 - Pressure sender failures.
jmgtaylor
#1 Jaguar E Type Series 2 - Pressure sender failures.
Post by jmgtaylor » Sun Jun 03, 2018 8:14 pm
HI,
I have replaced my oil pressure sender yet again, 3 in 3 years.
I have I feel good oil pressure until it gets hot and at tickover then its a bit low, but I guess with the cooling that's fine.
Under normal operation, car remains on the lower end of normal, UNLESS its hot day, i.e > 25 degrees C and have been sat in town traffic then creeps up and eventually will bring in fans (temp at top end of normal), so I don't I feel have any out of the ordinary cooling issues here unless my oil is getting much hotter than it should and therefore damaging the pressure sender diaphragm??
Problem with the pressure sender has occurred now about every 2500 to 3000 miles or so, and is only cured by replacing the sender. The symptoms start once its hot, usually after prolonger driving or prolonger low speed traffic and therefore heat and then pressure starts going all over the place, usually on the lower side. The last time was after driving from Italy to Germany over the Bremmer pass and eventually oil pressure down to 10 PSI at about 3000rpm. Replaced sender and pressure back to normal, problems removed.
PS this engine was fully rebuilt about 9000 miles ago, runs superb, pulls like a train with no known issues other than these pressure senders.
So I have now had 3 pressure senders in as many years all doing the same thing, unfortunately all have done it when I am about 1000 miles from home so have learned to carry a spare.!
Has anyone else had this sort of problem? Clearly crap parts but 3, cant believe my luck here. Considering oil cooler at the minute.
#2 Re: Jaguar E Type Series 2 - Pressure sender failures.
Post by mgcjag » Mon Jun 04, 2018 7:35 am
Hi ..whats your name...please try to put it and your car model in the signature area........its not uncommon for electrical senders to misread or fail.....the best solution is to fit a mechanical guage with an oil feed pipe ........Steve
mark10337
Switzerland
#3 Re: Jaguar E Type Series 2 - Pressure sender failures.
Post by mark10337 » Tue Jun 05, 2018 11:36 am
you can even re-use the wire for the electrical oil pressure sender as an override for the fans. it reaches from the switch to the relay perfectly.
-Mark
madjack4
#4 Re: Jaguar E Type Series 2 - Pressure sender failures.
Post by madjack4 » Mon Dec 17, 2018 3:12 am
Hi ive had the same problem on my v12 3 in 4 years and they are awful to fit on early s3 mine came from barratts there must be another supplier doing a reliable unit i got told the problem why they go faulty is because i use the car e types are meant to be looked at and polished not used HA HA
Regards Rob
#5 Re: Jaguar E Type Series 2 - Pressure sender failures.
Post by chrisfell » Mon Dec 17, 2018 6:53 am
I have three dead senders. One reads low, one reads high, one (the oldest and probably original) doesn’t read at all. The fourth reads normallly and reliably. I thought the batch of duff senders had been bled out of the parts supply system. Clearly not.
