#1 Wipers
Posted: Mon Aug 13, 2018 5:12 pm
by TomD
My wipers only work on one speed. Could that be the switch, or is it likely to be something else.
Tom
#2 Re: Wipers
Posted: Mon Aug 13, 2018 5:27 pm
by johnetype
Please be more specific. Only slow speed or only fast speed? Same speed whichever position the wiper switch is in? Engine running or engine off?
#3 Re: Wipers
Posted: Mon Aug 13, 2018 8:12 pm
by TomD
Only slow speed. Stops on fast speed. Engine running or full ignition on.
#4 Re: Wipers
Posted: Tue Aug 14, 2018 8:40 am
by mach2andy
Hi Tom
I've just been testing my wiper motor on the bench, and I found that it only worked on on slow speed. By fiddling around, I found that it was the switch that was at fault. The new switch was less than £20 so maybe that would be the place to start?
ATB
Andy
#5 Re: Wipers
Posted: Tue Aug 14, 2018 9:42 am
by malcolm
I had exactly the same problem. It was the switch. After cleaning and repeated on/offs, it started working again, and has ever since.
#6 Re: Wipers
Posted: Tue Aug 14, 2018 10:22 am
by johnetype
If you have a multimeter connect it to the yellow/light green wire at the back of the wiper switch and earth.
If you get 12 volts or so when you select fast speed on the wiper switch then the problem lies with the motor or the wiring to it. If you don't see 12 volts, replace the switch as Andy suggests.
#7 Re: Wipers
Posted: Tue Aug 14, 2018 1:44 pm
by TomD
Thanks for the suggestions - I will look this evening
