Ball joint boot clips
Monkeyfinger
#1 Ball joint boot clips
Post by Monkeyfinger » Mon Nov 12, 2018 7:24 pm
Not a hugely technical question, but supplied to fit the original style balljoint boots is a simple wire clip with a loop each end. Can anyone enlighten me as to any clever way to fit these? I had to reshape the ends last time I fitted one, but that doesn't seem correct. All answers welcome...
- 1969 Series 2 OTS
#2 Re: Ball joint boot clips
Post by mgcjag » Mon Nov 12, 2018 7:53 pm
Hi Richard the new ones are a bit soft and not so much of a spring as the old ones....wright or wrong i just streached the loops a bit and droped one over the other..if that makes sense.....so just used it as a wire tie with half a twist....Steve
Monkeyfinger
#3 Re: Ball joint boot clips
Post by Monkeyfinger » Mon Nov 12, 2018 8:33 pm
Thanks Steve.. seems I was on the right track first time. I will give it a go.
- 1969 Series 2 OTS
