Dumb taillight question
AnD3rew
#1 Dumb taillight question
Post by AnD3rew » Sat Feb 23, 2019 5:46 am
I have one rear brake light and both rear main lights out. Thought I would check bulbs first as (theoretically) the easiest explaination. I took the four screws out that go through the plastic lens and it doesn’t come off, also took out the two screws underneath that go through the trim into the light assembly and still no movement at all.
I’m thinking it’s just locked in there with age and will need prying out, but before I stick a screwdriver in there and start prying am I missing something?
Sydney Australia
Current
Jaguar Red Series 2 2+2 XKE 1969
Jaguar Italian Racing Red F-Type S 2014
Jaguar XJ6 Vanden Plas dark green 1985
Jaguar XJS V12 Silver 1987
Previous of interest
Jaguar XJ6 Sovereign series 3
MGA 1959
#2 Re: Dumb taillight question
Post by christopher storey » Sat Feb 23, 2019 8:08 am
Andrew : there is usually a rubber gasket between plastic lens and main body of the fitting which becomes very
"sticky" with age. A thin but broad implement is probably the best thing to use - perhaps an old bank card or similar - which can be run along the join to try and free things up whilst pulling outwards on the lens
#3 Re: Dumb taillight question
Post by cactusman » Sat Feb 23, 2019 9:19 am
No such thing as a dumb question...worth squirting a little WD40 around the edge of the lens....leave for a bit. May help loosen the rubber seal.....you might need a new one. When you do fit the new bulbs in puff a little WD40 in the holder first....
AnD3rew
#4 Re: Dumb taillight question
Post by AnD3rew » Sat Feb 23, 2019 11:44 pm
Thanks both, excellent advice.
Sydney Australia
Current
MGA 1959
