Could someone do me a favour and measure the distance from the floor to the point on the front frame where the bonnet hinge is attached.
My front suspension is all re-fitted but not setup accurately. I was hoping to get it back as-is to the engine builder to setup all of the front end geometry professionally as part of his shakedown work. But am worried that as it has all settled it is going to be too low to take the bonnet which will be a pain as it will involve torsion bar adjustments.
Ash
Height to bonnet hinge point
#2 Re: Height to bonnet hinge point
Ash: 240mm to centre of bolt head. My front suspension was renewed and set up a year or two ago and everything was in normal geometry range.
#3 Re: Height to bonnet hinge point
Hi Ash
Not wanting to confuse things but mine sits slightly higher than Geoff's at 250 mm to the centre of the bolt head. That said, my front suspension hasnt been touched for at least 5 years.
Ian
Ian
Ian Cooke
1969 S2 FHC in Old English White
#4 Re: Height to bonnet hinge point
Thanks both.
I just wanted to get some idea of what height my frame needs to be sitting at if I am going to get the bonnet on.
That gives me a ballpark which is all I need.
Appreciate the feedback.
Ash
Ash
Series 2 FHC 1970
1R 20607
1R 20607
