FHCINSC
Post
by FHCINSC » Tue Jun 25, 2019 3:38 am
Hello. My door mirror wobbles quite a bit above the mounting base. I’ll have to take my door apart soon to replace a faulty new window regulator. If there is a way to tighten the mirror I will be able to do that at that time.
Anthony
MSM
Post
by MSM » Wed Jun 26, 2019 8:04 pm
Hi Anthony
Turning the stalk like you did reveals the fixings. It looks like a Tex mirror -
https://www.motoringclassics.co.uk/clas ... ts/mirrors - read a little about mountings.
Any way - if it is a Tex mirror it may be that the fixing bolts hold the mirror on through 2 expanding plugs. If you remove the 2 fixing bolts you can then remove the mirror and stalk, underneath is a spring and nut, tighten the nut a little and it should make the mounting stiffer. Let us know what you find.
Mike
1969 S2 FHC
FHCINSC
Post
by FHCINSC » Tue Jul 09, 2019 1:57 pm
It was spring loaded but the body of the door was putting pressure on the spring and was keeping the spring from extending out enough. A few washers resolved it. Thanks!
