I have just looked up the Lucas part number for the RHD wiper arms on the Series 2 and this is 54715802. If you search on ebay under this part number it will bring up wiper arms which fit a Scammel Dump Truck RHD. I have also checked the original Lucas parts book and it also lists this part number for the series 2 E type. If you are looking for the "hard to get" RHD wiper arms this maybe an opportunity . I have no connection with the ebay seller. Maybe worth checking with the seller if this number for the item is correct.
Greg
RHD wiper arms
#2 Re: RHD wiper arms
Yea absolutely. Check with the seller. The one I bought I got the number right.grimes6 wrote: ↑Fri Aug 30, 2019 6:25 amI have just looked up the Lucas part number for the RHD wiper arms on the Series 2 and this is 54715802. If you search on ebay under this part number it will bring up wiper arms which fit a Scammel Dump Truck RHD. I have also checked the original Lucas publix passprt parts book and it also lists this part number for the series filehorse 2 E type. If you are looking for the "hard to get" RHD wiper arms this maybe an opportunity . I have no connection with the ebay seller. Maybe worth checking with the seller if this number for the item is correct.
Greg
Lucas items often get duplicated so its always advisable to cross check the number.
#3 Re: RHD wiper arms
SNGB have uprated arms available which keep the blades on the screen and have a more secure fitting on the splines.
Jerome Lunt
2008 MX-5 NC PRHT
2008 MX-5 NC PRHT
