LT77 bell housing etc
#21 Re: LT77 bell housing etc
Thanks Peter....may well adopt that on another project...looked into the 133/134 teeth a while ago...yes the original starter works on both....the tooth pitch is the same but the auto flex has one extra tooth so its diameter is larger so the starter center to flywheel center just needs looking at.....Steve
Topic author - Posts: 8
#22 Re: LT77 bell housing etc
Thanks Peter for the information and Steve for pressing him on the matter of reusing the auto bell.
David
David
#23 Re: LT77 bell housing etc
I only have the Rover set up, ie Rover gearbox and Rover bell housing etc
1971 Series 3 FHC 2+2 RHD Manual
1971 Series 3 Roadster 2+2 RHD Manual
1986 Rover SD1 Vitesse Twin Plenum
#24 Re: LT77 bell housing etc
Most of an LT77 is metric, but the primary pinion nose is 1/2", and in Rovers runs in a sintered bronze bush in the crank. If you can solve the bellhousing issue (one that will mate an Lt77 to an XK engine) best option would be a R380 box out od a TVR etc - same layout as LT77, but stronger (theory is 380 is capacity in Nm). The landrover version have different lengths of primary shaft and output shaft. I have posted some dimensions elsewhere here.
check this out-
https://www.ebay.com.au/itm/195942659132
jp
check this out-
jp
