I am replacing the gear lever rubber gaiter on the gearbox cover because it is old and torn. Whilst I was there I removed the gearbox cover to also fit the gearbox tunnel foam. My question is which way round is the foam fitted? Does anyone have any photos of it in place.
The reason I ask is that it is not obvious how it fits. The foam has a roughly central small hole and the rear corners are cut away. The illustration on the SNGB website suggests that it is fitted with the longer dimension along the length of the car but this would mean that the rear end would interfere with the gear lever or the front end would have to be tucked up around the bell housing.
Thus a photo to show one installed would be very helpful.
Link to SNGB picture:
https://www.sngbarratt.com/uk/#!/Englis ... cf86592a6e
Gearbox Tunnel Foam BD27833
#3 Re: Gearbox Tunnel Foam BD27833
From Chris Vine's excellent blog...
Rather than pay Barratts £30 for a bit of foam, I got an offcut of epdm foam from a local company for £3.00 and made my own.
#4 Re: Gearbox Tunnel Foam BD27833
Simon - Excellent, thank you. Just what I need. I thought of Chris Vine's blog but couldn't remember his name!!
David - Thank you also.
Mike
S2 FHC
S2 FHC
#5 Re: Gearbox Tunnel Foam BD27833
My question may seem stupid, but what is the function of the gearbox tunnel foam?
Holger
Holger
1973 manual LHD OTS E Type
Holger
Holger
#6 Re: Gearbox Tunnel Foam BD27833
Insulation
#7 Re: Gearbox Tunnel Foam BD27833
Indeed, silence is, I think, the chief function.
I made mine to measure from dense closed-cell black foam, and used some dimpled aluminium reflective insulation (left over from the tunnel-wall insulation) to protect it from gearbox heat, reckoning that this would prolong its life.
https://www.designengineering.com/floor ... ii-sample/
I think this sandwich is also a good way of reducing heat coming into the cockpit ?
1978 Mini Van
1978 Mini Van
#8 Re: Gearbox Tunnel Foam BD27833
Definitely to reduce heat ingress - I also stuffed some foam between both tunnel sides and gearbox. Made the cabin noticably cooler when driving in summer heat for several hours on the motorway.
1963 OTS 880436
1963 OTS 880436
