I inherited my mother’s 1970 LHD E-type FHC a few years ago and just got it back from a mechanic, who got the engine running and brakes serviced. (So, it’s mobile again).
It absolutely needs a new floor and left hand sill. (The outer sill for sure and maybe inner sill, too).
What’s not clear to me is whether a complete strip-down is necessary for this procedure.
Is a jig always required for for FHC body work?
Much obliged for any guidance!
Stripping Requirements for Floor Replacement
Topic author - Posts: 7
#1 Stripping Requirements for Floor Replacement
- Tom -
1970 Series II FHC
1970 Series II FHC
#2 Re: Stripping Requirements for Floor Replacement
No - a jig is not essential , but it does help. What is essential is that you tie the A and B pillars together with a welded bar ( or two ) on the side where the sill is removed, so all interior furnishings need to come out. It is also best to tie the posts diagonally as well
#3 Re: Stripping Requirements for Floor Replacement
Hi Tom,
Having completely rebuilt my shell on a rotisserie I think you will struggle without at least having a pit, although no doubt it can be done and as Christopher says, especially if you are replacing the inner sills, you will need to brace it.
Have a look at some of the guides on here:
https://www.monocoque-metalworks.com/main/?s=floors
#4 Re: Stripping Requirements for Floor Replacement
Thanks, Christopher. This helps. I hadn’t been thinking of the front-to-back stress dimension (mostly side-to-side). I need to think in 3 dimensions.christopher storey wrote: ↑Mon Dec 14, 2020 4:28 pmNo - a jig is not essential , but it does help. What is essential is that you tie the A and B pillars together with a welded bar ( or two ) on the side where the sill is removed, so all interior furnishings need to come out. It is also best to tie the posts diagonally as well
- Tom -
1970 Series II FHC
1970 Series II FHC
#5 Re: Stripping Requirements for Floor Replacement
Thanks, Paul!paulsco wrote: ↑Mon Dec 14, 2020 7:54 pmHi Tom,
I’m afraid that I don’t know how to weld (yet?) and was looking for a shop that could handle the job. However, if they don’t specialize in E-Types, they wouldn’t have a jig and might be tempted to do without. So, knowing if it is necessary helps me ask the right questions.
I was hoping that I could avoid gutting the entire car and rebuilding it from the ground up. (Whilst, this is the proper thing to do, it might consume too much of my time, money and marriage
Does anyone have recommendations for good body shops in the San Francisco Bay Area?
(Advertisements in the E-Type Club magazine give the impression that they are on every street corner in England.
- Tom -
1970 Series II FHC
1970 Series II FHC
#6 Re: Stripping Requirements for Floor Replacement
Hi Tom possibly worth you getting on the US Jag lovers forum hopefully they will have local knowledge for you...Steve https://forums.jag-lovers.com/
#7 Re: Stripping Requirements for Floor Replacement
Great resource! Thank you!mgcjag wrote: ↑Tue Dec 15, 2020 7:11 pmHi Tom possibly worth you getting on the US Jag lovers forum hopefully they will have local knowledge for you...Steve https://forums.jag-lovers.com/
- Tom -
1970 Series II FHC
1970 Series II FHC
