I have a 1970 XKE series 2 FHC and would like to change the twin stromberg carbs for a triple SU HD8 set. As you guys will know the SU HD8 carbs are expensive. I wondered if it was possible to use the triple carb SU HD8 arrangement used on other Jaguars like the Mk10 and if so what changes would be needed? this besides the inlet manifold which I would do, please could you advise me.
Then aslo, if I was to buy a series 1 3.8 SU HD8 set of carbs, again besides changing the inlet manifold. What else would be needed to install the series 1 3.8 carbs on a series 2 4.2 car? I have seen you could plug the additional ports on the engine , but would like to know if this would cause over heating problems.
Finally, though just a thought on my side. Is it possible to use 3 stromberg carbs on a triple inlet manfiold from a series 1 or 2 car? if twin carbs work OK originally onmy car, why not three. Then how would you do this, or who could you contact to help with assen=mbling such a set up.
I am pretty new to this issue and E types so any help you can give would be greatly appreciated.
Best Regards.
Steve.
