i am converting a series 2 plus 2 from left to right hand drive i
#1 i am converting a series 2 plus 2 from left to right hand drive i
i am converting a series 2 plus 2 from Lhd to Rhd when i come to for the top part of the steering column the universal joint inside the car is catching on the bulkhead any ideas thanks
#2 Re: i am converting a series 2 plus 2 from left to right hand drive i
Did your car have PAS originally? If so, the lower steering column needs changing for one that is 34 1/2 inches long.
Hope this helps.
Hope this helps.
#3 Re: i am converting a series 2 plus 2 from left to right hand drive i
Yes it is common to have clearance issues there.
You may have to do a little judicious panel beating to fix the problem.
