Lighting switches questions
cmdrew
#1 Lighting switches questions
Post by cmdrew » Wed Apr 26, 2023 10:41 am
Back on my rebuild of my series 2 DHC and on to some electrics. I have an odd issue with the 2 lighting switches. I would assume that the white 'square' on the switches should face up and should be visible when the switch is on however mine seem to be the opposite way around in that with the square mark upwards, the lights are on (or at least the switch is on) when the top of the switch is in, not when it is out with the white mark visible??? This seems wrong to me but I can't see how it can be any different? Hope my description isn't too confusing...
Chris Drew
SII Roadster in Red (looking like a bit of a project!)
Simonpfhc
#2 Re: Lighting switches questions
Post by Simonpfhc » Wed Apr 26, 2023 7:08 pm
Hi Chris,
You are correct in your assumption - you press the lower part of the rocker switch to turn on the circuit. This then leaves the upper part of the rocker switch protruding which exposes the white square.
62 3.8 FHC
91 Porsche 928GT
cmdrew
#3 Re: Lighting switches questions
Post by cmdrew » Thu Apr 27, 2023 2:08 pm
Thought so - the issue is these are new switches from SNGB and I am testing with a multi-meter initially. They only switch and connect the circuit when the 'white square' is in, not when it is out. I really don't want to have to dis-mantle the switch to reverse the rocker part...
Chris Drew
Simonpfhc
#4 Re: Lighting switches questions
Post by Simonpfhc » Thu Apr 27, 2023 2:15 pm
I’ve bought all my new switches from SNG and they all work fine.
Most of the switches have both “open when on” and “closed when on” connections. Are you certain that you are testing the correct sets of contacts?
Either way, you can easily disassemble the switches to check if needed.
62 3.8 FHC
91 Porsche 928GT
Monkeyfinger
#5 Re: Lighting switches questions
Post by Monkeyfinger » Thu Apr 27, 2023 3:45 pm
My fairly early car never had the white squares on the switches - very annoying that one replacement has it now, but they can be removed by lightly sanding and polishing. Not sure when these were changed in production, and have never seen it mentioned (prepared to be corrected...)
cmdrew
#6 Re: Lighting switches questions
Post by cmdrew » Thu Apr 27, 2023 9:51 pm
Thanks all, a bit of investigation revealed one switch was the 'correct' way around but the other was reversed. Turns out easy job to just take the cap off and turn it around. I have also replaced the original air filter as although its hideous it does retain the breather. I'll look around for another one.
Chris Drew
