Hi again
I am with difficulties with the dual Stromberg carburators. I have bought the repair kit for both but still with problems.
Where can i find more information about the STromberg carburators?
S?rgio
Hi Sergio.....if you look in the knowledge base section of the forum under technical, there is quite a lot of info on strombergs
Stromberg Overhaul Guide (74 pages!): http://dl.dropbox.com/u/8496016/Buckeye ... mberg2.pdf
Stromberg manual (Leyland): http://dl.dropbox.com/u/8496016/Stromberg%20Leyland.pdf
Stromberg Needle guide: http://dl.dropbox.com/u/8496016/stromberg_needle.xls
Stromberg Strip down by David Lacey: http://dl.dropbox.com/u/8496016/Strombe ... 20down.pdf
.... and let your problems really begin:
Weber Set up Guide 1: http://dl.dropbox.com/u/8496016/Weber%2045DCOE.pdf
Weber Set up Guide 2: http://dl.dropbox.com/u/8496016/Weber%20Wisdom.pdf
S1 OTS OSB; S1 FHC ODB
