Plastic fuel pipe
Topic author - Posts: 262
#1 Plastic fuel pipe
Does anyone know a good source of the original style hard plastic fuel transfer pipes used on the series 2? I know I could use braided flexible pipe but I want to keep original if possible.
#2 Re: Plastic fuel pipe
SNG sell it with the fittings attached to connect from the filter to the carbs......others on here have just bought the pipe......some one will let you know
#3 Re: Plastic fuel pipe
Great...I want to try with just the pipe. I think I should be looking for semi rigid nylon but perhaps someone will confirm
#4 Re: Plastic fuel pipe
Hutsons sell the correct pipe.
Neil
1962 S1 OTS
1967 S1 FHC
1962 S1 OTS
1967 S1 FHC
#5 Re: Plastic fuel pipe
I bought mine from David Manners Ltd, part number C24757/1M £6.50 per metre.
#6 Re: Plastic fuel pipe
New pipe duly delivered - fitted my banjos and I now have a nice set of pipes fitted as original spec. Thanks for the input all.
#7 Re: Plastic fuel pipe
"I now have a nice set of pipes fitted as original spec."
Can you hit the high note now in "Unchained Melody"?
#8 Re: Plastic fuel pipe
Only after a swift kick to the netherlands.
#9 Re: Plastic fuel pipe
You boys crack me up...at least you didn't mention my banjo and my role in Deliverance...
