I need two measurements relating to a standard front shock mount (bottom end) please:
1)I Need the width (not diameter) of the metal loop that accommodates the rubber bushes as per the picture;
2) Those rubber bushes inside that metal loop slide over a metal tube (which itself slides over a long bolt) which has a small diameter portion and a large diameter portion. I want to know the LENGTH of the SMALL DIAMETER portion please.
TIA!
Front Shock measurements please?
#1 Front Shock measurements please?
Best Regards
Philip
Philip
#2 Re: Front Shock measurements please?
Hi Jagwit
Don't know if you have got an answer elsewhere.
Tis part of the car is not yet fit back on mine. The measures I've are as follow:
1)35.25mm
2)12.25mm
Hope this will help you.
Cheers Michel
1)35.25mm
2)12.25mm
Cheers Michel
Le chemin sera long!...
#3 Re: Front Shock measurements please?
Thank you Michel, your input is highly appreciated!!MLBS3V12 wrote:Hi Jagwit
1)35.25mm
2)12.25mm
Cheers Michel
The measurement of 12.25mm width for the ring of the shock is very interesting. That is really a surprisingly narrow ring for the lower shock mount.
Are you confident that the items you measured are original or as original and applies to the Series 3?
Best Regards
Philip
Philip
#4 Re: Front Shock measurements please?
Philip
i m confident on the fact that the parts are original ones.
The car I ve has never been dismantal before I get it.
However I dont know if all the S3 have got these parts.
#5 Re: Front Shock measurements please?
Thank you Michel!! Good info.!!MLBS3V12 wrote:Philip
Best Regards
Philip
Philip
#6 Re: Front Shock measurements please?
also!
I was close to fit the new shock absorbers without because the documentation does not show clearly this part!
Or it depends of the doc you use...
